Old 08-14-2003, 09:05 PM   #1
2002Z28SSConv
2002Z28SSConv's Avatar
Internal construction of the T56
If I were able to get the CAGS to engage while in 3rd gear would it damage the solenoid? Would it lock the shifter in 3rd gear? Would it allow you to shift normally into 4th gear and not 2nd gear? That's the one I'm going for.
__________________
2002 SOM SS Vert M6: *****345hp package, K&N, Predator, Mac mids w/ORY, FRA, BMR STB, DMS springs, DMS Adj PHB, ST 35mm Front Sway Bar, !*! Z06 brake upgrade !*! , And yes, I'm autocrossing it yet again.
13.3 @ 106 stock! Convertibles are slow!
2002Z28SSConv is offline   Reply With Quote
Old 08-15-2003, 12:33 AM   #2
Rodrigues
I forgot what gears the CAGS locked out on, lol. In the detent assembly I saw how it worked, it just sticks out a little rod forcing the shifter from 1st to 4th. If you got it to engage while it was in 3rd, then the rod would just hit the metal around the guide groove and it wouldnt do anything.
http://kak.com/trans/DSCN1055.JPG
See the the groove in that plate inside the detent assembly? Thats the skip shift.
__________________
AIM: lt1pat
Rodrigues is offline   Reply With Quote
Old 08-16-2003, 01:20 AM   #3
OneFlyn95z28
Send a message via ICQ to OneFlyn95z28 Send a message via AIM to OneFlyn95z28 Send a message via Yahoo to OneFlyn95z28
Nope won't hurt a thing Cags will actually activate in any gear if going slow enough and it enters the engagment parameters
You would not even know save the light on the dash.
__________________
Ellis
"The Secret to Reliable Performance"
642RWHP/638RWTQ SAE
N/A 10.97@121 1.48 60Ft * N20 Coming
OLD TIMES**10.05@135 1.49 60Ft with an A4 to a 12 bolt hauling 3650Lbs!**
OneFlyn95z28 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
