rear end swap....4th to 3rd gen
Old Jul 23, 2002 | 05:47 PM
86 redbird's Avatar
Post rear end swap....4th to 3rd gen
Will the gears and posi out of a 2000 ws6 TA work with the stock rear on an 86 TA?
Old Jul 23, 2002 | 06:08 PM
mr diabolical's Avatar
as long as the t/a has a 10 bolt and not a borg warner 9 bolt, yes it will work.
Old Jul 23, 2002 | 08:52 PM
IrocSS85's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mr diabolical:
as long as the t/a has a 10 bolt and not a borg warner 9 bolt, yes it will work.</font>
buut you will need axles from a 89-92 car cause the new posi will have 28 spline and the old ones (88 and older I believe)have 26 spline. so check first. I found for me it was better choice to get complete 4 gen rearend. but you need diff. rims to fit the 2" wider rearend. I was buying rims/tires anyways and I came across a great deal on a 3:73(not orig. gears ofcourse) posi rear end out of a 96 trans am.
chris
Old Jul 25, 2002 | 12:10 AM
86 redbird's Avatar
so is that what everyone else thinks? I need to tell this guy if I want them or not
Old Jul 25, 2002 | 01:34 AM
Chuck!'s Avatar
Quick question on the break lines. I use the stock lines, but will my existing hard lines (drum) fit into the disc's rubber lines without modification?
Chet1185
Feb 4, 2015 09:51 PM
RiverMutant96
Jan 30, 2015 09:21 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
