doing a rear end swap... 3channel/4channel/tc questions
Old Aug 13, 2003 | 07:09 PM
Robert95z's Avatar
Im getting a rear end out of a 2002 SS with 3.42s... I dont know traction control and im not sure if this rear end does either, but i can find out. I also dont know if its a 3 or 4 channel ABS... How can i find out if mine is 3 or 4 channel ABS?
If i have a 3 channel, and that has a 4 channel can it still be put on my car? Also what if it has traction control? Like i said i dont have traction control...
I really want this rear end cause im getting it dirt cheap, i just need to know if I have to the EXACT same stuff as that rear end does... Thanks!
Old Aug 13, 2003 | 07:13 PM
madwolf's Avatar
You should really get a rear-end with the same options as your current one. If you have TCS and the new rear-end doesn't, that won't work same thing for vice versa.
AFAIK, the 2002 rear-end is a 4 channel and yours is a 3 channel. I'm pretty sure that also won't work.
Old Aug 13, 2003 | 07:35 PM
Robert95z's Avatar
Damn... anyway to make this work? like deleting the ABS? if so, how?
Old Aug 13, 2003 | 07:40 PM
Z95m6's Avatar
I believe you can make it work but you have to delete your ABS. There is a way to put a diff. rear in your car and keep the ABS but it is kind of involved. I will let everyone know how it goes when and if i complete it.
Old Aug 13, 2003 | 08:36 PM
94formulabz's Avatar
deleteing the abs, ha. Just hook it up. When the ABS realizes the sensors aren't working right it will just set off your light and won't interfere with anything. It'll work fine, u just won't have ABS.
If you want to make a four channel axle compatible with a 3 channel car you just have to bore the metric sized hole in the top of the differential and add a $20 tone ring to the ring gear.
I swapped a 4channel rear into my non TC car.
-brent
Old Oct 29, 2005 | 11:27 PM
Bersaglieri's Avatar
Re: doing a rear end swap... 3channel/4channel/tc questions
-brent
How did that work out for you. I did the same and have the ABS light on. How exactly can I make this work?
-Dustin-
Old Oct 30, 2005 | 12:24 AM
atljar's Avatar
You will need ls1 rear brakes too. The lt1 stuff wont ever get aligned right on ls1 rear.
Old Oct 30, 2005 | 12:36 AM
How about a 4 channel LT1 rear?
-Dustin-
Old Oct 30, 2005 | 12:51 AM
atljar's Avatar
Cant give you a good answer there. I went from 3 channel lt1 rear to 3 channel ls1. I shimmed here and shimmed there on the lt1 brakes to get them on and working. It would still go through a set pads in a few months. The alignment of where the rotor sits vs the caliper is different on ls1 to lt1.
I finally bit the bullet and bought ls1 brakes. No issues since.
For the 4 channel swap above....
Just an idea, just run one of the 2 rear channels into your single channel. It will only read the one sensor then, but should pulse correctly.
Old Oct 30, 2005 | 12:57 AM
Thats what my buddy said to do, just make a custom plug for it and as long as it got a signal it would work again. See thread in Brake section.
-Dustin-
Old Oct 30, 2005 | 04:35 AM
30696bird's Avatar
Surely you changed the backing plates???? I put a rear from a 1999 in mine..........changed the backing plates on the rear and have had NO problems.
Old Oct 30, 2005 | 10:38 AM
Robert95z's Avatar
wow this is an old thread
Old Nov 5, 2005 | 08:19 AM
atljar's Avatar
I tried using both LT1 and LS1 backing plates. My experience dealing with this was on a 12 bolt, maybe thats where the difference lies?
Old Jan 1, 2006 | 11:50 PM
I'm getting under there tomorrow to make it work. I'll let you know how that helps.
-Dustin-
Old Jan 2, 2006 | 06:50 AM
MustangEater82's Avatar
I have heard the single wheel sensor works.
I have a 4 channel in my 3 channel car. I was going to try the one wheel sensor to see if it works, just having a slight problem locating one. Think I have to hit the dealer.
FWIW I heard it plugs right into the same harness as your 3 channel ABS.
