Old 08-13-2003, 09:42 AM   #1
mook99TA
LCA"s
Just ordered the BMR boxed lca's and was wondering if I should get the relocation brackets too. What is the benifit and are they really needed?
__________________
99 TA Artic White
US ARMY OIF Veteran
Beer the cause and solution to all the worlds problems -Homer Jay Simpson-
http://www.cardomain.com/ride/2166632
mook99TA is offline   Reply With Quote
Old 08-13-2003, 10:27 AM   #2
SteveC
Smile
Good choice, I hope you got them with the poly/poly setup. If your car is not lowered, you probably do not need them (mine is stock height, and I did not). After the install, if the LCA's are parrallel (sp), or pointing slightly down on the axle side, you are o.k., if they are angled up on the axle side, you will need the relocation brackets to lower the angle.
SteveC
SteveC is offline   Reply With Quote
Old 08-13-2003, 02:22 PM   #3
mook99TA
Yes I did get the poly/poly is there any other! and thanks for the help steve
__________________
99 TA Artic White
US ARMY OIF Veteran
Old 08-15-2003, 05:13 PM   #4
bbentley40
Member
Like Steve said if your car is not lowered then odds are you will not need relos.
__________________
Bentley
2000 Camaro SS M6 #1879
324.2 rwhp 336.1 tq
bbentley40 is offline   Reply With Quote
Old 08-17-2003, 06:31 PM   #5
steelerfan
The relocation brackets will also help reduce/eliminate squat on launch which will give you better traction,resulting in better launches.If you aren't racing the car then it really doesn't matter,in fact some people like the squat because of the way it looks.
__________________
99 Z28 6 speed,flowmaster cat back,k&n filter,SLP cold air kit, lid,strut tower brace,& short throw shifter,Lakewood LCA'S,SFC's,drilled & slotted rotors.84 Camaro V6,stock,one owner
steelerfan is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
