Old 05-13-2002, 08:26 PM   #1
STRYKER
Question How 2 Keep From Nosediving
I will have new springs, struts and shocks coming soon. What, other than that, can I do to my old '91 RS to keep the front from nosediving so bad when I put on the barkes ?
Thanks,
-Stryker-
__________________
2002 Firebird-3800 V6-T5- Wifes car
1994 9C1 Caprice (X-Sheriff car) stock
1995 Z28 --> A4, midlength heaaders, 58mm TB, CC503, 1.65 HS RR's, etc.
In God We Trust, All Others We Run Through NCIC
STRYKER is offline   Reply With Quote
Old 05-13-2002, 09:57 PM   #2
ILLEGALZ28
Guest
Posts: n/a
see how it works after you install your springs and struts. yo umight see that if helps a lot with new stuff. what kind of springs are you getting. stoxk of lowering ones
Old 05-14-2002, 06:15 PM   #3
STRYKER
I am just getting the stock replacement springs for right now. I will be going with the Hooker Long tube headers soon and I don't want any clearance issues.
-Stryker-
__________________
Old 05-14-2002, 10:35 PM   #4
mrr23
Send a message via AIM to mrr23
adjust the rear brakes tighter. but the springs and struts will be the biggest help.
fl-thirdgen.org#0004
moderator @ www.fl-thirdgen.org '86 t/a, 3.27, auto, homemade CAI, hypertech AFPR, comp cams 1.52 roller tip rockers, holley prostrip annililator ignition system, shift kit,
OEM corvette 2100 rpm convertor, lakewood adjustable panhard rod and trailing arms, edelbrock 6872 headers, catco 6007 3" cat, flowmaster 17151 3" single outlet catback. 14.91 @ 90.57 177.7rwhp 356.4rwtq
__________________
99 formula
11.397 @ 120.96
00 formula
10.855 @ 127.17
mrr23 is offline   Reply With Quote
Old 06-24-2002, 01:32 AM   #5
black84 z28
Member
a spohn torque arm will reduce nose diving alot!
black84 z28 is offline   Reply With Quote
Old 06-24-2002, 02:49 AM   #6
92BLKL98
92BLKL98's Avatar
Quote:
<font face="Verdana, Arial" size="2">Originally posted by black84 z28:
a spohn torque arm will reduce nose diving alot!</font>
For sure, the Spohn TA was one of my best suspension mods
92BLKL98
'92 Black Z28 Hardtop Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods Random Technology cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
__________________
92BLKL98 '92 Black Z28 H/T w/Harwood 2" cowl hood,MSD Ignition,March U/D Ram air,SLP runners,24# inj,SLP 1 3/4 headers w/Pypes cats,Mufflex 3.5 cat back w/Spintech muffler,Amsoil synth. lubes,CE SFC's,Edelbrock STB,Spohn TA,Roadtech LCA's and PHB,PST susp,KYB Shocks,LPE 3.5" alum D/S,LS1 brake upgrade
92BLKL98 is offline   Reply With Quote
Old 06-24-2002, 07:17 PM   #7
STRYKER
Thanks guys, I will have to check that out !!
-Stryker-
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
