06-01-2002, 10:50 PM
New Member
LT1 in an IROC?
I have an 86 Iroc with a 305 that is starting to go out. I am thinking about swapping the engine for an LT1 out of a fourth gen. Does anyone know the horsepower specs on the LT1's. Also how hard is it to swap them? Are there any sites dedicated to the swap? Any info would be apretiated.
06-01-2002, 11:33 PM
Junior Member
I have a 350 in my 89 Iroc and its a LT1 (5.7TPI)
so it might be cheeper if you swap it from a 350 iroc......
later,
aaron
~Aaron~
1989 Camaro Iroc - Z28
5.7TPI
310hp
06-02-2002, 12:31 AM
Aaron, A 350 TPI and a LT1 are very different engines. No 3rd gen came equiped with a LT1.
Brian, a LT1 swap isn't all that hard. If you do a search on www.thirdgen.org 's motor swap forum you will find tons of info. They were rated at 275 and 285 hp. You want a 94-95 one if you are going to use the stock computer, they were sequential fire but still OBD I.
__________________
2002 Z28
2010 2SS/RS - #7881 - IBM/Black
06-02-2002, 02:02 AM
Member
Do a search here, theres about 5 or so members I've seen that have done this swap, myself included.
My website in my sig will provide you with SOME info, but its not really a guide...
Hope that helped!
Goofy's LT-1 87 Camaro
Status------------------
Car just needs paint job!
__________________
87z w/ LT-1
06-02-2002, 04:41 AM
I am in the process of building my LT1 into an LT4 heads, intake, and LT4 Hot Cam.
I have some pics of some of the progress here, http://www.donpagevideo.com/pics/lt1/
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, , MSD 6A & Blaster 3 Coil, LT1 3.42 Posi/Disc Rear, Lakewood LCA's &
Adjustable Panhard Bar, Jamex Lowering Springs, 17x9 WS6 Wheels,
T-Tops, Custom 4" CAI w/ K&N Filter, 160*stat.
Autometer TriplePod.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
__________________
1988 Firebird Formula WS6 305HSR T5
Mods: Lots of them
Pentium 60 Mhz, 32MB Ram, S3 Virge 4meg Video Card, 13" Sony CRT, 160MB Hard Drive, Windows NT v3.51
WWW.FormulaZR1.Com
06-02-2002, 01:42 PM
I start next week on my l98 to lt-1 swap, i excited. I here those lt-1's are pritty quik in irocs i dont know thow, does anyone have any times?
89' red iroc-z
386 stroker 10.5.1
ross pistons
eagle h-beam rods
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89'red Iroc-z 5.7 TPI
t-tops grey interior
free mods, exhaust
06-02-2002, 02:23 PM
Hey irocbob89...let me know how it goes and I'd like to check out the finished product. I'm in Chicago also and am just gathering everything I need to do the swap also in an '87 Trans Am to Lt1 6 speed. I'll probably start in the end of July if all goes according to plan. Good Luck!!!
SOLD: 1999 Trans Am, Silver, CAGS, IAT resistor, Screened out MAF, BMR STB, FlowMaster, LS1 Motorsports lid w/K&N. SunCoast WS6 style hood. B&M Ripper Shifter.
"The Surgeon General Never Said Nuthin' 'bout Smokin' The Competition"
__________________
SOLD: 1999 Trans Am
1987 Pontiac Trans Am
Motivated by an Lt1 and T56
http://www.unitsn4.cz28.com
06-02-2002, 06:51 PM
hey good luck to you to. where do you live? that would be great if we could compare notes or something. Ill post when i have a problem, i hope you will do the same. Ill be happy to show you when its finnished. later
Bobby
Im in Hoffman Estates
06-03-2002, 03:37 AM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by irocbob89:
</font>
Times are in sig. That was with a Moroso CAI and SLP headers and 3" exhaust. Other than that it is stock. The sorry 60' times will be fixed soon and then I should see much better ets. The mph is good though.
Pix of my rides!
Finally have some pictures of Y2k Vette wheels, motor, etc.
*1991 Camaro RS !LO3
8.84@85.3mph NA
*1988 Mustang 5.0 7.92@87 NA- For Sale
*1988 Mustang GT 'vert
9.56@73-bone stock
*1986 Kawasaki Ninja 1000R 7.30@100mph
*1987 Honda CRX Si 16.5@85mph-stock
100% American!
06-03-2002, 12:27 PM
Premium Member
I've got an LT1/T56 combo. Check out the website in the sig...it's been of help to a lot of people.
Eric
LT1Powered85Z
LT185Z (F4i, Stealth R/T TT, etc)
-'85 LT1/T56 Z28
-'01 Honda CBR600F4i
Administrator of The Minnesota F-Body Club
06-03-2002, 04:57 PM
I'm as far southeast in Chicago as you can go...the neighborhoods known as Hegewisch actually. I can spit on Indiana from where I'm at. I will post whatever problems I come across but like I said before...I'm not starting until the end of July...currently just accumulating parts. Man this is going to be some big bucks.
__________________
SOLD: 1999 Trans Am
06-03-2002, 05:06 PM
http://www.fuelinjection.com/portinj.html
http://350.streetracing.org/lt1.htm
http://sethirdgen.org/vss.htm
http://www.thirdgen.org/newdesign/tech/techdb.shtml
http://www.iroczsource.com/lt1.htm
http://www.sethirdgen.org/vats.htm
Here are a few links I've gathered that may help. Another thing I've read somewhere is that a passengerside motor mount from a '94 Caprice can be used with out having to do any modding to it. If anyone can verify this please do so.
Also, if anyone has any other good info sites, please post them.
__________________
SOLD: 1999 Trans Am
06-03-2002, 05:10 PM
What is the benefit of going with the LT1 (or even LS1) over a built Gen I motor with the TPIS MiniRam II intake?
Is the LT1 worth the wiring changes as opposed to building a 355 or 383 and running the TPIS MiniRam intake and using the stock ECM and burning your own chips? I ask because I have a non-LT1 350, 1 piece rear main seal block that I planning on using for a 383 build up and running the MiniRam II intake. Would it be worth considering the LT1 (or even a LS1) instead?
Eric Mann
eric91z@mchsi.com
'91 Camaro Z28
__________________
Eric
'03 Ford Crown Vic PI- Daily Driver
'04 Mercury Marauder - 1 of 997 silver Marauders - "Fun" car
F-Bodies Long Gone: '77 Camaro, '78 Firebird, '79 Trans Am WS6, '81 Z28, '86 Z28, '91 Z28, '93 Z28
06-03-2002, 05:28 PM
IMHO, its not worth the money. You can buy a set of noce heads, cam, intake and some extra motor mods and make a lot more HP's over the LT1 motor for about the same price.
Not to mention having to re wire the engine bay...
I'm building up a 383 with AFR heads and miniram II intake and its costing my just a little more than an LT1 swap would cost.
__________________
1987 Red IROC-Z / 383 TPI-Miniram II / T56
Pictures...
Start it up!
383 Eagle Forged L98 / Miniram II intake / AFR 190cc heads / JE/SRP flat top pistons (11:1 comp.) / Total Seal Gapless Nitrous Rings / Splayed 4 bolt caps / Cemented bottom half / Comp Cam - Custom Grind / 1.6 RR / BBK 58mm TB / Costum tuned chip (4now!) / T56 conversion / Spohn Suspention / 200 shot of NOS to be added later
Expecting ~400rwhp N/A
06-03-2002, 10:57 PM
these people have done many of those swaps. might want to check out their site(contact them) as they probably have tons of info as well
1992 Camaro RS LO3/700R4
Holley 600 Double Pumper, Weiand Stealth Intake Manifold, Hedman Headers and Modified Hedman Y-Pipe(Ported and 3" Pipe), Straight-Pipe Cat, Flowmaster 3" 2 Chamber Race Muffler, 160º thermostat, 3.73 Posi, Boxed LCAs, Kumho 255/50s, Polyurethane Transmission Mount, and B&M SuperCooler.
Waiting To Be Installed: ZZ4 Cam
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
