TPI Max HP
Old Jun 9, 2002 | 03:50 PM
racr4jc's Avatar
Post TPI Max HP
What's the most horsepower y'all would trust a totally stock TPI setup to? I mean everything from base manifold to computer.
Kenny
Old Jun 9, 2002 | 03:53 PM
GMTech's Avatar
Depends... Naturally Aspirated or not? Running boost kinda does away w/ the airflow limitations TPI presents...
As for a bone stock, N/A TPI, I don't don't have an exact number, but I think whatever it is, would suprise alot of people.
Although my base is home ported, my runners and Throttle body are stock, and my time is in my sig..
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
Old Jun 10, 2002 | 01:43 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Hey Kenny, you're local to me! Welcome to the group. Check out the local club at http://www.sc3g.org/ if you havent already.
I made 282 HP and 380 TQ to the rear wheels with a ported stock TPI intake, L98 heads, a ZZ4 cam, and SLP 1 5/8" headers. It ran a best of 13.23 @ 107.18 MPH. With some clever porting known as the siamese-job, you can make a stock TPI intake perform very well. I wish I would have done it before I put my current engine together, who knows how much power it would have.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Jun 11, 2002 | 01:36 AM
ZDADDY92's Avatar
The stock TPI setup is pretty limited. The whole system is restrictive to begin with, and I am almost possitive that the stock computer cannot take more than 218 duration without going crazy. Pretty much if you go with a big cam you are going to have to upgrade the chip, along with the manifold, runners, etc. The list is endless-I have learned this the hard way. It really depends on the cam that you go with......I am still learning on this, so I can't give you all the details just yet.............
92 Z-28
305TPI-5speed
3.42gears
B&M RIPPER
K&N AIR FILTERS
Hypertech Fan Switch
160 THERMO.
14.7@96MPH(stock run)
Old Jun 12, 2002 | 10:02 PM
racr4jc's Avatar
Thanks for the replies. The motor is an all-forged 383 with DartII Sportsman heads which have been extremely ported. The motor is eventually going to be turbocharged and I expect 600+ hp to be my eventual goal. However, that is with the right cam and what not. Currently it has a '97 silverado cam to keep things on the down low. I have a TPI setup lying around and wanted to utilize it, but I feel it just won't be adequate. For now I'm just going to run the motor naturally aspirated with a Performer RPM and a carter carb and upgrade from there. SEFI is likely down the road. BTW, its goin in a first gen. Thanks for the info.
KeNnY
  • '68 RS in the works, Ritchie Racing Red
  • '99 Z28 (dad's car) white
  • '92 Sierra also white
Boost: The replacement for displacement
Old Jun 13, 2002 | 07:50 PM
Yellowknifer's Avatar
Well since you seem to have time to do it, it might be worth a try. The TPI setup excells at low end torque and can be very effective up high with a good port job (siamese it!) Since you have that silverado cam it might worth your while as I'm sure you're making plenty of power down low .
Old Jun 13, 2002 | 10:15 PM
Kevin91Z's Avatar
Oh ok, I thought you had a thirdgen since you were asking about TPI setups. Check out the local all-gen f-body club at http://www.socal-fbodies.org/ We've got some very nice first gens in the group as well.
G-BODYT56
Jan 14, 2022 11:14 PM
linz
Oct 22, 2015 07:59 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
