Old 06-07-2002, 09:16 AM   #1
f-bodyv8
Junior Member
Question What problems will I have with a 383??
Hey Guys I am in the process of building a 383 to go into an 88 to 92 Camaro. My question is How hard will it be to install a motor with a carb? I plan on pulling the old motor with the T.P.I. I was told that these cars have 2 computers 1 for the engine & drivtrain and 1 for the rest of the car. Is this true? also Where would be a good place to look for suspension parts? I know this thing will have problems hooking up? What is the company G2 or G3 I have seen it in alot of guys Sig.s.
Thanks Ahead of time Guys
Tony
My car 1997 30th anniversary Z-28(LT-1) W/ T- Tops, Automatic(4L60E) w/traction control, 3.73 gears, k&n cold air kit, 160 thermostat, march under drive crank pulley, flowmaster muffler, Hypertech Power Programmer 13.9 @98mph
__________________
Project Car 1986 IROC Z Coupe 305TPI
From Walbridge, Ohio
By Toledo
f-bodyv8 is offline   Reply With Quote
Old 06-08-2002, 03:12 AM   #2
newby
Well, I put a 383 in my 86 Z as a replacement for a 305, and ended up just ripping all the computer stuff out. It wasn't TOO much work, but I also pulled the EGR stuff off too. Biggest problem was a twisted frame (before Sub-Frame connectors) and a blown tranny:-)
1986 Z28
383 ci Stroker, Dart Sportsmen 2 heads, roller rocker arms, Crower Hot Street Beast cam, edelbrock 750cfm carb and performer rpm intake, Corvette Servos, shift kit and 2600 rpm stall convertor, 3.73 gears and Eaton limited slip posi rearend.
__________________
Powered by 2 furious triangles and a snail.
newby is offline   Reply With Quote
Old 06-08-2002, 02:36 PM   #3
Intercepter
Same thing here. Got rid of the computer and all the unwanted wiring. Cleaned up the engine bay alot. You will need to buy stock in your favorite tire company, cause your going to be sending them alot. I sure do!
Intercepter is offline   Reply With Quote
Old 06-08-2002, 09:34 PM   #4
IgorT.455/406
IgorT.455/406's Avatar
Send a message via ICQ to IgorT.455/406
I went from 305 TBI to 358 carb. Was super simple. Just drop the motor in, get a $4 relay from a local parts store for a fuel pump. Hook it up in place of the stock relay so that when the ignition is turned on, the stock fuel pump will work. Get a Holley Blue (if TPI, get two Holley Blue) fuel pressure regulators. Hook them up to stock fuel line comming into engine compartment from tank. On the second one (from where you will hook up your carb), run a return line to the stock return line. Hook up your carb, your distributor using pretty much the stock wiring harness, and you are good to go. If auto trans, then you will have to wire in a switch for lockup, but ask someone else about that. Your stock computer you can yank and throw out, car will work fine and that fuel pump will keep up ok 360 HP or even more. Best of all, if you keep your computer in there and harness intact, you can always bolt the EFI back in.
When the key is in run possition, fuel pump will work, if the motor is not running, the return line will return the excess fuel back into the tank. Nice, simple. You can use all your stock accesories, electric fans (need a swtich for that, but no big deal), etc. Everything will work good. Any more questions, just e-mail me.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
__________________
1988 Trans Am WS6, 383/th700/9" w/4.11s; Holley 750 carb, Victor JR. heads/intake and a Comp Solid Roller cam!
1995 Trans Am LT1/T56, Functional Ram Air Hood, just got it....
R.I.P. now parts car - 1994 Trans Am LT1/T56;
IgorT.455/406 is offline   Reply With Quote
Old 06-10-2002, 09:57 AM   #5
f-bodyv8
Junior Member
Thumbs up
Hey guys thanks for all the input. It helps knowing that I can turn to guys already running the set up that I am attempting to go with.
Thanks A Bunch
Tony
__________________
By Toledo
Old 06-10-2002, 12:17 PM   #6
brodyscamaro
everything has been pretty much summed up. i switched to carb and so far have left the harness and computer in there mostly because lack of time ripping everyting out. you dont necassirly have to wired up a switch for the torque converter but to do it click the link below.
http://www.thirdgen.org/newdesign/te...ueswitch.shtml
1992 Camaro RS LO3/700R4
Holley 600 Double Pumper, Weiand Stealth Intake Manifold, Hedman Headers and Modified Hedman Y-Pipe(Ported and 3" Pipe), Straight-Pipe Cat, Flowmaster 3" 2 Chamber Race Muffler, 160º thermostat, 3.73 Posi, Boxed LCAs, Kumho 255/50s, Polyurethane Transmission Mount, and B&M SuperCooler.
Waiting To Be Installed: ZZ4 Cam
[This message has been edited by brodyscamaro (edited June 10, 2002).]
__________________
1992 Camaro RS
brodyscamaro is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
