BFG Drag Radials or Nitto's
Old Jun 5, 2002 | 12:36 AM
IgorT.455/406's Avatar
Post BFG Drag Radials or Nitto's
Hey guys. Well, I am seriously considering getting either of these tires to mount on my '88 TA wheels. This way, even if I take the '94 to the track, I can bolt the wheels from the '88 on there and have some sticky tires. I primarly use the '88 for thrashing on it, so it would work well. Which do you guys think would be better, Nitto's or Drag TAs? Which are cheaper? Thanks.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
Old Jun 5, 2002 | 10:33 AM
1989gta's Avatar
if your just using them for the track why not get some e/t streets. better hook for similar price.
Old Jun 5, 2002 | 10:37 AM
Do they make them for the 16" rim? Do they make them stock tire height? Thanks.
Old Jun 6, 2002 | 10:22 AM
91Bird305's Avatar
i have seen some guys on here selling some for 16' rims. Check the motown muscle garage sale board too
www.motownmuscle.com
1991 Firebird 305
Eric Natzke
"It ain't Stock"
http://members.aol.com/j007golden/91firebird.html
[This message has been edited by 91Bird305 (edited June 06, 2002).]
Old Jun 7, 2002 | 08:25 AM
f-bodyv8's Avatar
I have 4 friends running the Nitto's They all say that the Nitto's are great on the track and on the street. also not so scarry at high speed. I hope this helps even though it is through word of mouth not first hand
Tony
(the 4 cars 99Lighting 12psi w/150 shot 12.2et///00lighting stock 13.3et///94 Z auto full slp exhaust cold air 13.7et///88mustang bunch of bolt ons 13.5et)
My car 1997 30th anniversary Z-28(LT-1) W/ T- Tops, Automatic(4L60E) w/traction control, 3.73 gears, k&n cold air kit, 160 thermostat, march under drive crank pulley, flowmaster muffler, Hypertech Power Programmer 13.9 @98mph
Old Jun 9, 2002 | 02:27 AM
IrocSS85's Avatar
I just got my 275/50/15 nittos. love them. car runs 13.67 best (first time at track w/this car/eng. and lots to play w/still) and it got 2 1.92 60's and the rest were under 2.02. w/20 psi never spun (but didnt launch from full stahl either, did try 2k launch a few times though) the nittos were $154 ea. shipped from www.tires.com and the bfg.s were $130 ea. plus $5 shipping from summit. Ive heard the nittos are better traction, but bfg's last longer. Id recomend the nittos.
also, you do know that your 3 and 4 gen cars use two diff. offset rims right? I have a 4 gen rearend in my Iroc so my 15 x 10" rims w/7.5" offset will fit both my 86 and my 95. just have to shave the rear calipers a little. no big deal.
and, noone had my size bfg.s in stock. as for stock size, they make 255/50/16's in both which will fit on stock rims perfect.
chris
Old Jun 9, 2002 | 05:12 PM
I used my 4.10 4th gen rear in my '88 as well until I got my fourth gen car. Now, it is there. The '88 rear wheels fit on my '94, I have bolted them in before with no problem. They stick out just slightly compared to the stock ones, but work great!
Old Jun 9, 2002 | 11:27 PM
steve10358's Avatar
3rd Gen Tech Moderator
Moving to Drag Racing forum.
Steve
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
