LS1 aluminum driveshaft?
Hi guys, are LS1 aluminum driveshafts a direct swap for 3rd gens?
I've looked for the 3rd gen driveshaft on ebay but they seem kind of scarce.... but theres a 4th gen on there all the time.
If its not a direct swap what has to be modified to make it fit on a 3rd gen?
thanks
Paul J.
thanks
Paul J.
Guest
Posts: n/a
Is it really much of a pain to swap out (IE in labor costs)? I dont have access to a lift or anything right now, and I have no experience with driveshafts, so I wouldnt have a clue anyways.
If I were to get this shaft, what else should I make sure that I get with it?
The driveshaft is swapped with only 4 bolts. You dont need a lift you could easily do it in your drive way with a jack and jackstands, or drive on ramps. The swap shouldnt take more than 15 min. If you know how to use a wrench, you can change your driveshaft.
Unless you have a bad vibration problem around 80 MPH, the Pro & Con are a toss -up. One advantage for me was the light weight on the drive line. Otherwise no real SOTP feel with one.
Save your money.
Save your money.
Originally posted by doug791
it saves weight, reduces spool time, and reduces vibration. Doing it in your driveway would be a pain anyways because changing u joint without the proper tool is a pain.
Q: Will an aluminum shaft help my performance?
A: YES! It allows the engine and transmission to spool up faster due to less rotating mass. You will feel a difference. In addition an aluminum drive shaft has stricter production specifications and is alot more stable at higher speeds
Courtesy of www.thirdgen.org
