Should I get 3.73's with my converter
Old Aug 8, 2002 | 08:33 AM
Firehawk#69's Avatar
Post Should I get 3.73's with my converter
I came across a good deal for some 3.73 gears. I currently have 3.23's and a Yank ST3200 with a 2.2 str. The gears and the install will be a little over $300. I think that is a good deal, but how will they be with my converter? Some guys are saying that you will only gain a .05-.1 in the quater mile from the gears with that stall. Traction would be an issue, but the acceleration should be sweet. Will the 3.73's help from a 30-35 mph roll? What other mod for around $350 would be worth doing? Any input is appreciated.
2001 T/A firehawk Mods: SLP lid,k&N,baker hose,ls1 edit, ST3200, offroad y-pipe, cutout
Old Aug 8, 2002 | 10:18 AM
Trevor98ramair's Avatar
Cool
Considering you can get everything done for the a little over $300, it may be worth doing it. I can vouch that you'll gain very little w/ the gear swap with stock internals. I picked up a whopping .02 in the 60' with the 3.73's over my 3.23's. When you're running an aftermarket converter and stock internals, you stand to gain very little with a gear swap. If it were me, I'd just stick with the 3.23's for now. I lost 2.5 MPG on the highway after swapping to the 3.73's. As you mentioned, traction will DEFINITELY be an issue after the gear swap. It will be fun from a roll, but you'll run into problems from a light, even with the 3,200 stall. I know that traction was a big issue w/ the 3.73's and Vig 3200. I couldn't consistently hook anymore with that combo on ET Streets! The Hoosier slicks work well, though.
Trevor - LGM
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
