One mean turbo
Old Jul 9, 2003 | 05:50 PM
iwantals1's Avatar
One mean turbo
Sorry if this topic has already been discussed.. lurkin around and i stumbled across a guy throwing a deisel engine turbo on his 95 Vette... Good pics and vid...
http://forums.nasioc.com/forums/show...5&pagenumber=1
Old Jul 9, 2003 | 06:33 PM
96TurboTA's Avatar
I believe Texlurch is running two "diesel" turbos. Don't know what size they are.
Old Jul 9, 2003 | 10:08 PM
got_hp?'s Avatar
thats a pretty intersting buildup..........looks like hes also injecting some sort of cooling into the system (the guy building it starts posting on the 3rd page as "baldturbofreak")...........weird..............won der how itll work out.
Old Jul 10, 2003 | 12:44 AM
teamsleep13's Avatar
Ya that guy has *****, for his intercooler he is using an AC system to act as the coolant for the liquid to air intercooler. I don't know the specidfics, but he has designed a whole speperate system just for the intercooler.
Should prove interesting.
Hunter
Old Jul 10, 2003 | 03:38 PM
snorkelface's Avatar
I was introduced to the concept of using the A/C system while reading on the forth coming F*rd Lightning. It seems to really make sense. I'd love some info on how to make that work with a tradition supercharger system on an LT1. Combine that with water injection, and you could really make some extra power, and increase the longevity of your motor.
Old Jul 10, 2003 | 04:15 PM
texlurch's Avatar
Yep, two turbos off a GM 6.5 diesel. They spool pretty much at anything over 1/4 throttle. I can launch in 2nd and at about 3/8 throttle the tires start hazing. Right now 1st is pretty much unusable , as soon as the throttle is stabbed, it zings into the rev limiter faster than I can shift.
I read thru that entire thread.. I love all the guys saying he can't run 10 psi on his LT1.. hell he lowered his compression down to 10, I am running 12 psi on stock compression and 93 octane. Motor loves it so far!
Just keeping an eye on the plugs for any warning signs..
Turbo off diesels work fine, if sized correctly.
Old Jul 10, 2003 | 06:30 PM
GhostZ's Avatar
Now this is the funniest thing I've read in that thread:
" Obvioulsly has NEVER spent any time with the 4L60E
Those things with a mild build up will hold 1000hp every day no prob. I know of a twin turbo C4 Vette with 1126rwhp that's been running (and seriously dragging) on a mildly built 4L60E for 6 years. "Not built to handle more power"? Man, are you trying to sound like you don't know sh*t about Vettes and GM? Cause it's working. "
BWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
My stock 4L60E blew with just over 400 ft/lbs. Mildly built 4L60E running for 6 years on 1100+HP LMAO......I needed a good laugh today!
Old Jul 10, 2003 | 08:31 PM
Jimmy17's Avatar
speaking of deisel turbos
got a huge kick out of that :P
Old Jul 13, 2003 | 10:50 AM
iwantals1's Avatar
Re: speaking of deisel turbos
I think its a turbo off a submarine or something similar..
Old Jul 13, 2003 | 11:14 AM
I remember reading in Hot Rod a year or so ago about turbos. They had a picture of a turbo off an oil tanker, and the outlet of the compressor was 13 feet in diameter, and the inlet, well there was a guy inside of it.
It made something like 5 psi, but flowed like 600 lbs/min.....just insane.
Hunter
Old Jul 14, 2003 | 02:41 PM
racr4jc's Avatar
he must have meant 4l80e...shows how much he knows about GMs
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
