making a Fbody handle like a Z06?
I was wondering if anybody knows if it would be possible to get a 98+ Fbody to handle almost as good or even better than a Z06. Now of course their is the weight difference but what can you do about that, and the T-Tops that come on almost every friggin Z28. But I read in "Car and Driver" the Z06 pulled a 0.96 in the skidpad, could you forseable put those same parts or similar parts on a Fbody to make it handle just as well or is the suspension set up too different?
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
Its been said that with Bilstien shocks, eibach springs and some BFGoodrich G-Force T/A KDW(S) that the camaro will pull .9 or somewhere close to that, so my guess is that if you added all that with a strut tower brace, and sub-frame connectors you could probably achieve that
99 Z28RS
SLP LoudMouth
SLP Air Temp Module
MTI Carbon Fiber Air Lid/K&N
EGR Mod,FRA Mod
99 Z28RS
SLP LoudMouth
SLP Air Temp Module
EGR Mod,FRA Mod
It will take a WHOLE lot of things to get a fourth gen close to Corvette handling, and even then you'd probably be just close. That's what the car was designed around, to make it a street legal but race ready machine. They are perfectly balanced with their weight front to back (50/50), and they are made to haul @ss turning in any direction while doing it. The Camaro's however are built to burn the back rubber off and hang the @ss out while doing it. The ole live axel makes for some fun at the auto-x events!
1992 Camaro RS 25th Aniversary Edition, White, 3.1L MPFI V6, A4, catback exhaust with Flowmaster 80 Series, K&N with modded airbox, Eibach Pro-Kit lowering springs.
1999 Camaro SS #4224, Navy Blue Metallic, M6, Pro 5.0 shifter, whisper lid, and ported maf ends.
How to make a Z28 handle like a Z06???
Basically: extend the wheelbase by 3", widen the stance by 2", lose an extra 300lbs, and replace the live-axle rear and less aggressive front suspension for a tuned, 4-wheel independent system. That should just about do it!
OR: buy a Z06!!
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - No Pics yet.
OR: buy a Z06!!
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Dec 7, 2014 06:01 PM
