anyone going to fastest streetcar shootout @ Grand Bend next weekend?
Old Jul 4, 2003 | 12:46 AM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
just wondering who is going?
also can i register and pay at the gates there if i go saturday morning?
still debating!!!!!
Old Jul 4, 2003 | 12:22 PM
derty's Avatar
I would have loved to, but we are tearing the car apart right now. Prognosis is not good. Posi exploded, sent a chunk through the cover. Spider gears are exploded, center shaft in the posi is bent. One spider gear is fused against the opening and the posi next to the ring gear, that wiped out the pinion gear which in turn wiped out the ring gear. The axles could spin their respective spider gears but it wouldn't spin the posi and ring gear. That was fused pretty solid. I think that did some damage in the trans.
Output shaft is still firmly attached in the trans. I'm going out now to drop the trans out and look. I think it wiped out parts of the cluster.
Taner, I did not call that number you gave me as I've chosen an alternate solution at this point. Thanks for the info though.
Old Jul 4, 2003 | 01:27 PM
Capn Pete's Avatar
Arrow
The 11th, 12th, 13th weekend? Yep, I'm definitely going to that one Taner! I'm going with a guy from work and a couple of his friends are going as well I believe.
Now I know I may not have "the fastest" street car, but if I could get my traction issues somewhat straightened out, hopefully I'd be cutting times closer to 12.9 - 13.0, and then I'd be just a little more competitive!?
Well, maybe we'll see ya there?
Old Jul 4, 2003 | 04:19 PM
taner's Avatar
Derty,
no problem, hope it isn't as bad as you thought originally!
Capn Pete,
cool, i have yet to completely decide but if i go it should be fun! hope to see you there as well.
Old Jul 4, 2003 | 04:29 PM
derty's Avatar
It's not too bad. It did wipe out a couple gears/synchros and stuff. I'm going to tear the tranny apart later but we can already tell whats up. No damage in the bellhousing though. Have fun at the race.
Old Jul 4, 2003 | 10:35 PM
squinn's Avatar
I should be there as long as I get my car back together and every thing works the way its spoz to.
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
Sep 18, 2015 03:46 PM
RX Speed Works
Sep 11, 2015 03:31 PM
