Need advice,,, drivers side window leaks in rain.
Old Jul 5, 2002 | 11:27 PM
Ray66
Guest
Posts: n/a
Question Need advice,,, drivers side window leaks in rain.
Has anyone had a similar problem? Just noticed this today in a hard down pour in my hometown. The leak is located at the top of the window where the big pieces of rubber meet and form a crease and right above your dead. It's the side window not the T-tops. I own an 01' so it has to be covered under warranty. It's not a huge leak but it drips about every minute or so. Is this rare or a common problem with Camaros?
Old Jul 6, 2002 | 10:04 AM
ponch333's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ray66:
</font>
I had a 99 Z that dripped where the drivers side window met the rubber seal. I think it is the rubber seal of the T tops that meets the pillar that leaks. Any way The dealer told me they had a guy that comes in on wednesdays to fix the leaks under warranty. So there is a fix and yours should be covered under warranty.I never bothered to have mine fixed and I sold the car.
Former owner of a 99 Z28
SLP cold air induction
Whisper lid
K+N filter
Ported MAF, Flowmaster muffler with stock tips
Now my old stand by, a 94 Chevy C1500 with a 4.3 v6. At least it is extended cab and paid for!!
Old Jul 6, 2002 | 12:27 PM
rncotton's Avatar
Owned 2 F-bodys ... they both did this. It's not bad ... just a drip every now and then.
There is a tech note that provides specific instructions on how to adjust the window glass to properly fit the rubber seal. Unfortunately, after 5 trips to the dealer, they never did get the Camaro to completely stop (although they did improve the fit). I understand that the glass has 4 adjustment points.
If you're under warranty and can spend some time with your dealer (I.E. several trips and you'll need to provide your own alternate transportation) then let them try to fix it.
Old Jan 27, 2006 | 10:27 PM
Oxygen454's Avatar
Re: Need advice,,, drivers side window leaks in rain.
I have the same problem but no warrenty :S I have heard of siliconing between the rubber and the inner frame which is part of the front windshield. Also the little plastic piece that is held down by a screw under the t-top can leak. I am yet to try all this advice I was given but the weather just wont let up! The plugs under the rear seats came in handy to open and drain out the puddles. Not sure if there is plugs in the front and would have to remove the carpet hold-downs. Sounds like vasoline or K-Y is the best way to go to see if that is in fact the cause from poor seal between the window and the seal itself. Any other ideas?
Old Jan 28, 2006 | 08:37 AM
shoebox's Avatar
You can try adjusting the window.
Old Jan 28, 2006 | 01:23 PM
SFB767's Avatar
I had the same problem as you.
When my power windows both died and I had two new motors installed, they pushed the window up against the t-top MUCH better and there has been no leaks since then.
Once your power windows motors die, your t-tops will stop leaking.
ChrisFrez
Feb 22, 2015 08:47 AM
ModdedNerd
Jan 29, 2015 07:23 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
