how do you install a MSD window switch??
Old Jun 29, 2003 | 11:31 PM
TMDZ28's Avatar
i got my window switch. i got my pills to set the nitrous to shut off at. i got a red pill to start the nitrous with. i got all the wires and everything, but i dont know how to install it. can somebody give me a diagram or instructions or something to install this thing on an LT1??? thanks guys
Old Jun 30, 2003 | 10:18 AM
Hawk's Avatar
did u check the MSD website?? You can prob DL it fro there. SOrry i don't know off hand what color wires go where. Maybe someone else does but I'd do a search on the manufacturer website first. Good luck
Old Jun 30, 2003 | 11:42 PM
TMDZ28's Avatar
i tried to go to msd website, but i could not find it. is it that easy to install though?? i'm calling a performance shop nearby to install it, i just cant figure it out...
Old Jun 30, 2003 | 11:50 PM
craigffb's Avatar
Try this. It should help you out. I put one in when I installed my NX kit.
NX install
Old Jul 1, 2003 | 06:10 AM
HungryT/A's Avatar
I have one set up on my dry NOS kit. The wiring goes as following:
Red - 12v source, I hooked it directly to the positive side of the battery
Black - Ground
White - RPM signal, if you've got a MSD box it's plug and play. Otherwise you have to find the white wire for the tach signal
Yellow - this provides a ground for the nitrous kit. The nitrous relay should have a ground wire, or, in the NOS kit, the throttle microswitch has and end that should be grounded.
Good luck
Old Jul 1, 2003 | 10:28 AM
TMDZ28's Avatar
Good luck
dont i have to connect some wires to my coil?? does LT1 have coils?? thanks for the help, i'm just too much of an idiot to understand ut
Old Jul 1, 2003 | 10:30 AM
TMDZ28's Avatar
NX install
thanks man, that helps out a lot
Old Jul 1, 2003 | 02:42 PM
HungryT/A's Avatar
Err..as far as I know you have to find the wire that provides the signal for the tacho.
The LT1 has one coil. Ls1's have eight:blah:
Old Jul 1, 2003 | 03:29 PM
kirschman's Avatar
heres another one for ya http://gallery8926.fotopic.net/photo.php?o=1&id=550122
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
thenewkid
Nov 27, 2014 09:41 AM
