06-01-2002, 03:32 PM
Adding rear -wheel horsepower.
I have a 1998 Z28 and was wondering what the best way to add on 100-150 rear wheel hp. Also, I have an after market SS hood for my car which I would like to make functional (hook it up to the induction system) where can I get a kit to do this?
I looking for any suggests other than turbo charging, thank you.
__________________
2001 Z28. Artic White.
M6, SS hood, Shock Tower Brace, Sport Appearance pkg., Ported, Polished MAFH, SLP 85mm MAF, SLP Lid, KN air filter, Free ram air Mod., SLP 160 Thermostat, SLP Loudmouth Exhaust, Custom Stainless tips, T-tops.
06-01-2002, 05:13 PM
Junior Member
Yea get heads, oversized cam, hooker long-tube headers, and a cutout and u should be close to 450 hp.
06-02-2002, 12:15 AM
NOS
98 Z A4
STOCK NUMBERS
289.7 HP
312.4 TRQ
13.378 Best Time
[This message has been edited by BLU98Z28 (edited June 02, 2002).]
06-02-2002, 10:03 AM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by BLU98Z28:
NOS
</font>
Its Nitrous, N.O.S is a brand
DaveD
The Phantom of CamaroZ28.com
1998 WS6 #207
1998 Regal GS
"Snoogens"
Http://PhantomTA.cz28.com
I am a proud supporter of.... "Boycott Lapeer Dragway"...
__________________
When I first came here, this was all swamp. Everyone said I was daft to build a castle on a swamp, but I built in all the same, just to show them. It sank into the swamp. So I built a second one. That sank into the swamp. So I built a third. That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle in all of England.
06-02-2002, 10:09 AM
Member
Yea that will do the trick...Heads/cam/hookers and stuff..Geez thats a page right out of my book...Thats EXACTLY what i have. Good rear suspension setup to is going to make a difference..You need something to be able to put the power down to the ground.
Seth
__________________
1998 Firebird Formula
Mods? I think it would be easyer for me just to list the things that aren't changed in the car.
2003 Ninja 250R
06-02-2002, 04:32 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by bottlenose:
Yea get heads, oversized cam, hooker long-tube headers, and a cutout and u should be close to 450 hp.</font>
I was looking at headers it sounds like a good option, but what are "hookers" and "a cutout"? I'm new at this game I just got into the Camaro business about 9 months ago.
Also, I don't really what to put in a cam, my car is an everyday driver. Do you have anymore suggests?
1998 Z28 Flowmaster Exhaust, SS Hood.
__________________
06-02-2002, 05:12 PM
Member
Hookers would be a Long tube header... the cutout is basicly a tube that directs the exhaust out before the muffler or cat or what have you. So it allows you to run straight exhuast no restrictions when you want and when you don't you cap the cutout. Comp cams makes alot of cams that could be used for daily driving... The cam i have is really good but its on the mild side... But i love it... 216 220 i believe is the specs on mine..Like i said its mild compared to whats out there... but i will pass emissions and stuff which is more then i can say for alot of the other ones out there.
Seth
What do you do after you have fulfilled a dream? Open your eyes and take a pee...close your eyes and chase another one.
__________________
2003 Ninja 250R
06-03-2002, 12:47 AM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by PhantomTA:
</font>
It was a joke lighten up.
06-06-2002, 08:10 PM
You can get an air induction kit at suncoastcreations.com to make your hood functional
__________________
Level 3 Rockstar
94 Z - Cammed, not slammed, but still botta-bam.
06-09-2002, 11:04 AM
Member
I vote for a heads & cam setup getting its air from a set of twin turbos that are sucking their air through an NX MAF nitrous setup .... I think it'll meet the hp requirements .
__________________
'71 RS/Z28: 500 hp 454, MSD, RG M6, Centerforce, Lakewood BH, 4WDB, Guldstrand suspension, Bilsteins, SFC's
'01 WS6 M6: 338/427 rwhp, NOS 5177,Borla, Whisper, Prokit, Koni DA's/F, Bilstein/R, G2 Race APHB, LCA's, LCA brackets, BMR STB, 200 mph Granatelli speedo, SLP f/s, CAGS, B&M Ripper, 5 point RB, 5 point harnesses
06-09-2002, 12:35 PM
Member
If you go with the heads and cam setup then you will have a very relable power...Superchargers, Turbos, and Nitrous will shortin the life of any engine and their parts...Without having the right build up it is likly that sooner or later you will blow or break something costly.
Seth
__________________
2003 Ninja 250R
06-09-2002, 01:18 PM
Member
What is your goal for ET? What do you want to accomplish with 150 addittional rwhp? Goals can be met with less hp sometimes than you might think. My vote is h/c if you want 400+ rwhp.
2001 Camaro SS M6
11.901@115.82 1.71 60 ft.
342 hp 355 ft/lbs
Boltons running on DR's
1990 Eclipse GSX M5 stock for now
__________________
2001 Camaro SS M6
Lid,filter,Rapid Stage II LS1 Heads,Rapid Custom Grind Cam,Ram VDS 910,Ported LS6 Intake, SLP 160 Thermostat,SLP line lock ,ARE Ported TB,QTP long tube headers,Rapid Custom Y pipe,Cut-out,Pro 5.0 w/Lou's Short Stick and more to come
443.8 rwhp 406.9 rwtq
www.rapidmotorsports.com
11.901@115 1.71 60' with boltons 342 rwhp 355 rwtq
06-09-2002, 04:34 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Think U Can:
</font>
I would ET of about 12 flat, but I don't really want a cam. I'm just looking for bolt ons.
'98 Z28. Sports appearance pkg. White, T-tops, loaded. Flowmaster Exhaust,Custom Stainless tips, SS Hood.
__________________
06-09-2002, 04:47 PM
Member
Get some gears (3.42 or 3.73) and a torque converter for an A4, and for an M6 get some 4.10's. Best mod i have done so far.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
-Borla (the expensive cut-out)
-Wisperlid W/K&N
-FRA
-Cags eliminator
-Strange 4.10's
-G2 Rear Girdle
-Valv. Synthetic 10W-30
-Redline gear oil
-Fat hurst shift knob
-Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtr 900.2, Kicker 12L7 in a milhouse, Focal polykev K2's.
__________________
'02 BRR Z28 M6, hurst shifter, Borla, Wisperlid W/K&N, Bauer TB, g5x1, HAL QA1's, eibach prikit in back, bmr LCA-LCA reloc.-adj PHR, QTP LT's, TTII's, Panasonic dfx99, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev 6.5 K2's.
borla and lid => 330.2 rwhp 344.4 rwtq
06-09-2002, 06:44 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by redz_02:
</font>
What gear is stock on a '98 Z28, because that is all I have. Also, my car is an everyday driver so what size gear would you recommend. I don't want such a low gear as a 4.10 that's just too low, I travel too much for that.
However, I bet you pull hard as hell out of the hole though, right?
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
