Differences in 91 and 92
Old Jun 21, 2003 | 07:04 PM
Pro
Guest
Posts: n/a
Question Differences in 91 and 92
Hey guys can yall tell me much about the differences in the 91 and 92 model Z28s? Is it worth saving the extra $$$ for a 92 model?
Thanks
Old Jun 22, 2003 | 12:43 AM
Z_Ghost's Avatar
The only difference between them is the 92 was the anniversary year and was also the last year for the thirdgens. Other then that they are the same.
Old Jun 22, 2003 | 01:00 AM
Patriot's Avatar
Front grill between the driving lights was "Black "on all 91's . On 92's the grill is painted whatever color the car is . Here's my '92 Z
Old Jun 22, 2003 | 04:50 AM
Dirt Reynolds's Avatar
In 1992, GM made a major effort to tighten the f-body, with more welds, seam filler/caulking and so forth. The '92s are the quietest and tightest of the 3rd gen line.
Other than that, not much difference from the '91.
Old Jun 22, 2003 | 10:51 AM
Pro
Guest
Posts: n/a
I appreciate the info.
I wonder if the tighter suspension can be modded on the 91 models? 91s are much more easier to find it seems and if there really isnt all that much of a difference then maybe it would be worth it?
Old Jun 22, 2003 | 04:29 PM
Sure. The '91 is an excellent car, and you are right, there are a lot more of them around than '92's.
If you find a really nice '91 that strikes your fancy, get it. I really like the looks of the '91-'92 Z-28 and GTA's.
Old Jun 22, 2003 | 06:27 PM
Pro
Guest
Posts: n/a
Awesome. Hey what do you guys think of this car?
http://www.autotrader.com/findacar/v...or=&cardist=98
I called the guy a couple of days ago. He didnt say much, but if there is anyone in this area that could check it out for me that would be AWESOME. Ill even pay for your help, heh.
Old Jun 22, 2003 | 09:34 PM
Thats an RS. TBI 305 engine. I'd pass.
Old Jun 22, 2003 | 11:48 PM
user 647483's Avatar
1992 CHEVROLET CAMARO, RS, B4C police pkg, 1LE brakes, 350 V8, auto/OD, 92K mi, fully loaded, green grey
$4300/cash
Thta's not a bad car actually, assuming it is what the guy says it is.
Under 100k too
Old Jun 23, 2003 | 12:47 AM
I didn't see the fact it was a B4C.
The police-spec Camaros have all the good stuff. If it runs good and looks good, I'd seriously consider purchasing it.
Old Jun 23, 2003 | 12:44 PM
Craz-28's Avatar
Exactly. All the benefits of a Z-28 in an RS package. Plus the lower insurance that an RS gets over a Z-28.
Old Jun 23, 2003 | 07:00 PM
ATI426's Avatar
I'm not exactly positive but pretty sure that they didn't make the b4c package available with a 350 motor in it, especially an rs. I had a friend who bought an old police car (which was in rs badging)and it had the 305 tpi where as most rs had the tbi setup. I would look into it a little more as something doesn't seem right. You can check on thirdgen.org as they have a lot of info. like that on their site. I would almost bet that it is a manual transmission and that would be a 305ci from the factory as there were no 350ci and manual trannys from GM made. Unless someone put a 350 in it afterwards.
Brad
Old Jun 23, 2003 | 07:08 PM
Pro
Guest
Posts: n/a
Everything I have seen on the net says that the B4C has a 350 and auto with 3.23 gears...
Old Jun 23, 2003 | 07:30 PM
Zrated383's Avatar
I have seen different numbers about production numbers of B4Cs from 1992, but I am pretty sure the production number is 589. If the car is in good shape and seems to be running good (unless you like projects), definitely try to get someone down there to check it out. Seems like a great price, although it does not look mint.
Here is a description of the B4C cars from www.thirdgen.org
Q: What's included in the B4C police package?
A: It was an RS Camaro with air conditioning, Z-28 power train, 140 amp altenator and came with some (but not all) of the 1LE option package equipment. This included dual cats, special suspension, 4-wheel disc brakes, posi-traction, special axle ratio, oil cooler, 16" aluminum wheels, 145 MPH speedometer, and 245/50ZR16 blackwall tires. In order to determine if it is a true B4C, look for the "B4C" code on the option label located inside the glove box.
Good luck!
Old Jun 23, 2003 | 08:43 PM
Pro
Guest
Posts: n/a
Thanks Zrated for the help. If is has the 140 amp alternator, then that means it uses the cs-130 alternator casing (sorry, have forgotten part numbers) ?
