Sohn.net
Old Jun 21, 2003 | 06:37 PM
Shaun 90 Iroc's Avatar
Sohn.net
My Iroc did not come with the wonderbar steering brace. So i decided to finally order one fabricated by spohn performance.. and it does not fit. When i got to bolt it up, it runs into the bottom of the dual fan setup before it can be lined up to bolt up. Anyone else have a steering brace from spohn.net or could i see what the stock wonderbars look like? Thanks
Old Jun 21, 2003 | 11:54 PM
LT1Powered85Z's Avatar
Are you mounting it on the underside of the car, or inside the engine bay? It should be mounted underneath the car, basically just above the sway bar.
Eric
Old Jun 22, 2003 | 01:26 AM
AutoRoc's Avatar
Lightbulb
I was just happy to see that my wonderbar doesn't fit with the Spohn front sway bar.... Possibly why they made their own. They should market the two items together. just a thought!
Like the guy above said, hopefully you're mounting it correctly, under the car, in between the sway bar and frame... goodluck
Old Jun 22, 2003 | 04:49 AM
Zepher's Avatar
Here is a stock GM Wonder Bar,
and the BMR Wonderbar
These were installed on my 86 Trans Am
Old Jun 22, 2003 | 02:29 PM
LOL.. you guys have to give me more credit than that.. i knew where it bolted.. i loosend the endlinks.. unbolted the sway bar bushing.. and dropped the sway bar down.. and went to fit it up there and the front of the wonderbar hits the bottom of the dual fans. See in Zepher's first pic where the bottom of the fans are bolted down about 1/4-1/2 inch from the bar.. the spohn wonderbar runs right into them before it is forward enough to line up with the holes for the sway bar bushings. If i had a camera i would take a pic of it.
Old Jun 23, 2003 | 04:03 PM
ttt
Sohn said he knew what it would take.. he said they just grinded down the fan hold until it fit.. interesting.. oh well.
