How do I go about cleaning a convertible top?
Old May 30, 2002 | 01:18 PM
Mike94ZLT1's Avatar
Post How do I go about cleaning a convertible top?
Hey guys, I've never posted on this forum but hopefully you can help me out. I just picked up a Mystic Teal 95 Z Convertible, and I want to clean the top on it. It is black cloth. Any suggestions? Thanks!! -Mike
Old May 30, 2002 | 02:40 PM
KevinSS's Avatar
First, you should know that the material on the F body tops is made by this
company http://www.haartz.com I use their brand name spray cleaner and then
seal the fabric with 303 Fabric Guard.
I sell both products along with my Zaino supply.
Here is the procedure;
Important: A program of keeping the top clean through regular washings BEFORE
it gets dirty, will enhance the life and beauty of an acrylic top and make successive
cleaning easier.
Most automatic car washes will not harm sport topping fabrics. Washes with water
jets and hanging cloths are preferred. Those using heavy barrel brushes should be
avoided. Haartz recommends hand washing in the shade or partial shade, not direct
sunlight.
Bird and tree droppings as well as other loose particle soils should be removed
immediately. Vacuum the top with a brush attachment and rinse the roof fabric
thoroughly with water to remove these loose particle soils. This will also prevent the
soils from being redeposited during the cleaning process. Once the top has been
rinsed thoroughly, spray apply Haartz Roof Cleaner evenly over the entire top while
the top is still wet. Washing with soap and warm water is a safe alternative to
Haartz Roof Cleaner, but not as effective. DO NOT USE DETERGENTS. Allow the
roof cleaner to soak into the top for 10 to 20 minutes and then scrub the top lightly
with a soft nylon brush or terry cloth rag. Rinse thoroughly, preferably until no
remaining soap foam is observed. Allow to dry. Additional cleaning may be
required. It is best to determine this after the top has dried completely. After drying,
cleaning must be followed by re-water repelling the fabric with a fluorocarbon
system such as 303 High Tech Fabric Guard . Failure to do so will result in rapid
resoiling of the unprotected fabric.
The fabric itself does not promote mildew growth. However, mildew may grow on
dirt and other foreign substances that are not removed from the fabric. For these
more stubborn cases, soak the fabric for approximately 20 minutes in a solution of
no more than ½ cup (4 oz.) bleach and ¼ cup (2 oz.) Haartz Roof Cleaner per gallon
of water and scrub lightly as indicated above. Excessive soaking with the bleach
solution can deteriorate seam threads, so be sure to rinse thoroughly.
Rinse entire vehicle to remove all of the bleach solution from fabric and to prevent
streaking on painted and chrome surfaces. Acrylic fabric readily absorbs water but
dries quickly. Several cleanings may be necessary.
Do NOT use top dressing cleaners or conditioners containing silicones, organic
solvents, petroleum distillates or plasticizers that may permanently stain the fabric.
This product is made from 100% solution dyed acrylic fiber which is thermoplastic.
Do NOT subject to excessive heat.
The use of stronger cleansers should be left to professionals experienced in handling
this type of fabric to avoid discoloration and degradation of the special protective
inner layer
96 Black Impala SS
www.zainobros.com
Remember #3
Old Jun 1, 2002 | 10:51 AM
blkZ28Conv's Avatar
Thumbs up
Can not add anything to KevinSS. I have owned a triple black 95 Z28 convertible for almost 7 years. I have followed that procedure except I use Amazing Roll-Off as the cleanser (www.propercare.com) and The Haartz Protectant by Wolff.
95 Triple Blk Z28 Convertible - "garage queen"
WildRidez
Feb 23, 2015 07:24 PM
nosliw
Feb 7, 2015 01:30 PM
squarehead
Nov 21, 2014 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
