disc brakes on a 67 camaro
Old Jun 2, 2003 | 06:19 AM
hot936spd's Avatar
i have a 67 camaro, and im replacing the front drum brakes to disc brakes, and I purchased, spindels, and disc brakes off a 71 monte carlo. What all do i have to do to make that work thanks,
Please email me at
Mustanggobbler@aol.com
Old Jun 2, 2003 | 12:56 PM
CHPshown67's Avatar
the complicated part of the disc conversion from a non-camaro donor is matching brake line fitting sizes to calipers and the master cylinder. I bought a pipe flaring kit and match the right sizes to the lines, and flared them on. You also need to figure out what master cylinder you need with the right pushrod length. You obviously cant use the old drum camaro brakes, and if you got all the components from the monte carlo, that probably will work, but i dont know for sure. The 69 chevelle master cylinder and boost unit worked perfectly on my 67 camaro.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
Cam's maro
Jan 8, 2015 05:01 AM
hotrodyou1
Dec 20, 2014 10:05 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
