Prices & Installing a Torque converter? 9.5"?
Old Jun 1, 2003 | 07:02 AM
98BlueWS6's Avatar
I am going to have a torque converter installed. Are all converters for the LS1 9.5" or are some of them 10". I am looking to get one 2800-3200 stall. After pricing them they run anywhere $300 (midwest and others) - $700(Vigilante, Yank). Are some of them that much better for the price.
During the summer my car is a daily driver, if I go with a 2800-3200 how bad does it affect the gas milage. Any info would be appreciated.
Thanks,
JEREMY
Old Jun 2, 2003 | 04:57 AM
98BlueWS6's Avatar
ttt
Old Jun 2, 2003 | 12:13 PM
SLPSSLS1's Avatar
I have never herd a bad thing about mid west, and is the most bang for the buck. though vigilante is an amazing stall converter.
Old Jun 4, 2003 | 06:26 AM
98BlueWS6's Avatar
anyone?
Old Jun 4, 2003 | 08:40 PM
95TealLT1's Avatar
I have the Midwest 3000 stall (2.5 STR) converter with 3.73 gears in my 2000 Z28 and I get 16 mpg in the city and 24 mpg on the highway. Before the gears and converter it was at around 17.5 mpg in the city and 26 on the highway.
Not enough difference to worry about.
The Midwest cost closer to $500 not $300 but it has proven to deliver very acceptable results. I had a Vigilante with my 95 Z28 and it also delivered excellent results. Both work better with a shift kit.
The installation of the converter was $300 (including fluid, filter and gasket) and $170 for the install of the shift kit. ($50 for shift kit and $120 labor including fluid, filter and gasket) The shift kit was done later. On my 95 I used a Transgo that cost $120 and my friend that is a mechanic helped me.
A good 3000 stall converter is one of the best Mods for an automatic you can do.
You won't regret it.
Good Luck!
Al
Old Jun 4, 2003 | 10:46 PM
98BlueWS6's Avatar
It looks like the converter is $335 http://www.raceconverters.com/iStreet.htm
I think this is the right one for it, it is the first one on the page. It also says for up to 350hp and it would be more than that.
I also found a place to install one for $200.
Old Jun 4, 2003 | 10:49 PM
Joshs99BlackBeauty's Avatar
would a 3600 with 3.73 gears be too much?
Old Jun 5, 2003 | 07:11 AM
95TealLT1's Avatar
This web sight (www.raceconverters.com/iStreet.htm) does not show a converter for the 4l60E tranny. The one you need is located at http://www.hpaparts.com/default_main.asp
Good Luck!
Al
97TA-WS6-Con
Feb 1, 2015 01:14 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Jason Short
Jan 19, 2015 06:34 PM
Collector Car
Dec 17, 2014 01:12 PM
