Speedometer Problem
Old May 25, 2003 | 08:43 AM
Camaro91RS's Avatar
Angry Speedometer Problem
Hey
Well lately when I first take off......my speedometer doesn't even move for about 20/30 seconds. After that it goes up to about where I'm running and starts wobbling. Lately I don't even think it's been accurate....I'm guessing it's 5 under. It still wobbles even after driving for hours. Does anyone have any idea's? Thanks
also please check out my post about the energy problem
Old May 25, 2003 | 09:26 AM
Lungz's Avatar
what year? it could be an old/worn speedo cable if it's a mechanical speedo, if electric, I don't know, maybe someone else here has an idea.
Old May 25, 2003 | 09:48 AM
Camaro91RS's Avatar
It's a 1991 Camaro RS 305 Automatic....not sure if it's mechanical or electric :-/
Old May 25, 2003 | 09:52 AM
Bristol's Avatar
Its electric....two large multi wired connections plug into the back of it. Maybe youve got a loose wire? When mt tach went nuts it turned out that the tach wire was screwed. I just ran a new wire to the coil fromt the connection on the firewall and shes all good.
Old May 25, 2003 | 10:10 AM
Camaro91RS's Avatar
How do I get to those plugs though?
Old May 25, 2003 | 10:27 AM
Bristol's Avatar
Drop the lower dash pad(just above your feet) pull the headlight **** off and hang onto the clip that sometims comes off, lower the tilt of your steering wheel, I think (i cant remember) there may be two upper and two lower screws that hold the speedo trim on, pull the trim gently after the srews are gone on it should pop out, disconnect the defog and cig. lighter and twist the trim slightly to pull it off the column. The cluster is held in by two upper and lower screws and then gently wiggly the cluster out. Its really easy. Maybe a 2 on a scale of 1-10. Good luck.
Old May 25, 2003 | 03:05 PM
Camaro91RS's Avatar
Cool
Thanks dude...I really appreciate your help....I'll give it a shot!!! do you know where I can get the new wires though?
Old May 25, 2003 | 05:26 PM
Bristol's Avatar
Im not saying that it is the wires but just when my tach went nuts thats what it was. Try finding a wiring diagram and make a jumper wire to see if thats what the problem is. Good luck buddy
nosliw
Apr 27, 2015 04:01 PM
Jubjub
Mar 19, 2015 10:23 AM
mattstrike
Mar 12, 2015 10:12 PM
sdn1997rs
Dec 30, 2014 08:30 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
