Question about stock program and Tunercat
Old May 24, 2003 | 08:48 PM
super83Z's Avatar
I read the stock prgram in my PCM. Then I went to the speed calibration table and it said that my PCM was programmed for 3.07 gears, with a 285 50 17 tire. And the Y-car option was selected not F-car.
Is this just a generic table that pops up with a stock tune? Should I change it to what my car really has?
BTW it is a 1995 Z28 A4 with 3.23 gears and 16" wheels stock. I now have 17" 10-spoke wheels on there.
thanks
Old May 25, 2003 | 01:42 AM
Dan K's Avatar
You're correct in thinking that is just the generic table that pops up. It doesn't give you any indication of what you're car has at all.
What size tires do you have on those 17's?
Old May 25, 2003 | 06:49 PM
super83Z's Avatar
I have 275/40/17's. Should I enter in all the correct information when I reprogram my fans?
Old May 25, 2003 | 10:16 PM
atljar's Avatar
Imagine that window as just a calculator. If you enter all your info, then click apply, you will notice the adjustment numbers change at the bottom. Those numbers are the one that the computer uses to read vehicle speed. The tire size/tranny/ etc options just allow tunercat to calculate the correctionj factors and program them into your tables with numbers which have no meaning to us.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Injuneer
Dec 15, 2014 09:36 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
