08-14-2001, 10:44 AM
How to remove light oxidation ?
OK, I'll admit, I know absolutely nothing about polishing my car, for a show car finish. The paint is slightly oxidized. I've heard all of you guys talk about the 3M 39009 polish. Would this remove the oxidation? I have Zaino, and have successfully used it on my girlfriend's truck. I also have a random orbit buffer, that I had planned on using. My question is, should I use a wool pad, foam pad, waffle pad, etc? To remove the oxidation, and give me a good clean surface for the Zaino ?? Thanks for the help.
Brandon
94 Red Z-28 Hardtop A4, Superior 4.10 gears, T/A Rearend Girdle, Flowmaster Muffler, HPP+, B&M Shift+, !TB, !CAT, !AIR, !EGR, NGK TR 55's, Taylor 8MM wires, Clear front signals, Tailblazer brake light covers, TransAm T-handle shifter, Tinted windows.
This car is FOR SALE !!! Check out the pictures on my website.
Vettenut's Homepage
__________________
Current:
1998 Ram 1500 Sport pickup & an '01 Beetle.
Previous:
1998 Pontiac Grand Prix GTP
94 Red Z-28 Hardtop
Vettenut's Homepage
08-15-2001, 01:18 AM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Vettenut97:
More than likely.
Foam pad for 39009, apply the polish in a thin lined growing circle starting from the center and spacing the growing line about an inch from the last round all the way to the edge. Place the bonnet flat on a panel and
activate the polisher and begin working the entire panel using light to medium pressure. When you have worked the panel thoroughly then take a clean towel and wipe the residue off in a back and forth motion using light pressure. Then simply move to the next section. When the entire car is done do a Dawn wash and Zaino.
Brandon
</font>
96 Black Impala SS
www.zainobros.com
Remember #3
__________________
PAY PAL ACCEPTED
www.tnzaino.com
08-15-2001, 09:21 AM
Thanks, Kevin. You 'da man!!  I don't care what all these other guys say about you. haha
Thanks !!!!!
Brandon
Vettenut's Homepage
__________________
Current:
Previous:
94 Red Z-28 Hardtop
Vettenut's Homepage
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
