Old 05-20-2003, 09:16 PM   #1
gearslammer
What were the stock gears in the '95 Z28 8 cyl. cars
__________________
go fast or go home
02 Z28 vert black, M6, Corsa CB, Direct-flo airlid, K&N filter, Granatelli 85mm MAF, Dyno tuned, SSRA, Qwik Stick, Smooth Bellow, TB bypass, STB, C&C heads and cam, PPC LT headers, ORY-pipes !CATS, rear trailing arms, panhard bar, relocation brakcets, torque control arm, SFC's, LCA's, KYB AGX shocks and struts, Eibach anti-roll kit, 90mm throttle body, 275/17/40's, Custom Fikse rims. (430rwhp, 390rwtq)
gearslammer is offline   Reply With Quote
Old 05-20-2003, 09:45 PM   #2
Z_Maniac
I believe all Auto's came with 2.73s and M6s came with 3.42s... but someone can chime in incase I'm incorrect.
__________________
1994 Camaro Z28 - A4
CC305, Crane 1.6 SA, 52mm BBK TB, Hooker 1-5/8 Shorties, LS1 Rearend swap w/ 3.42, Flow Catback, Hotchkis Adj PHB, SLP Level One Susp, MSD 6AL w/ 6K RPM Pill, LT4 KM, Taylor Spiro OTV, NGK TR6s, B&M 24k TC, LT1 Edit, TTops conversion.
Z_Maniac is offline   Reply With Quote
Old 05-20-2003, 10:07 PM   #3
shoebox
shoebox's Avatar
3.23s were also "stock", but optional with A4s.
shoebox is offline   Reply With Quote
Old 04-21-2004, 03:38 PM   #4
Red95M6Z28
Red95M6Z28's Avatar
Send a message via AIM to Red95M6Z28 Send a message via Yahoo to Red95M6Z28
So do ALL M6's have 3:42's? Did any get 3:23's? Is there a way to tell what gears you have based on RPMs@speed?
__________________
Quote:
Originally Posted by ZeeDaddy View Post
The price is not negotiable because the goverment will bail me out to the tune of $4500.
This one sentence is exactly whats wrong with our country! Welcome to the Obama administration and the giant downward spiral....
Red95M6Z28 is offline   Reply With Quote
Old 04-21-2004, 03:40 PM   #5
Red96Lt1
Red96Lt1's Avatar
Send a message via AIM to Red96Lt1
All M6's had 3.42
__________________
1996 Z28 M6, 278RWHP, 307RWTQ, 187k
Jet hot LT's, Coated Hooker ORP, turbo muffler, DMH dual 3" cutouts, K&N CAI, LT4 KM, NKG iridium plugs and Taylor OTVC wires, MSD coil, 1le elbow, Air foil, MadZ28 tune, LS1 brake upgrade w/ss lines, SPEC Stage 2, BMR LCA's, BMR track pack TA, BMR boxed SFC's, DS safety loop, BMR 32mm front sway bar, BMR PHB, 1LE shocks and spings, B&M shifter, Warlbro 255 fuel pump, fan switch, poly mounts, !EGR, !AIR, !TB, !CAGS, !Cats
http://toddmink.com/camaro
Red96Lt1 is offline   Reply With Quote
Old 04-21-2004, 11:00 PM   #6
Z28Boss
I have a 95 Z and I think I have the 3.23's. How can I tell, I once heard something about having a 1st gear selection on the shifter. Oh yeah, I have an A4. Is it true that if I have the 1st gear selection, I have the 3.23's??
__________________
95 Silver Z28, K&N filter, TB Bypass(GOOD FREE MOD!!), Straight pipes.
Its only worth driving if you can do something stupid in it.
Z28Boss is offline   Reply With Quote
Old 04-21-2004, 11:13 PM   #7
Capn Pete
Capn Pete's Avatar
As long as your car is stock, then YES, if you can select 1st gear, your car has 3.23's. If you had an LS1 car though, that rule no longer applies (all autos can select 1st gear).
Go to www.f-body.org/gears to verify your gears.
__________________
2002 Z28: M6, 3.73's, Strano Suspension (HP3) - Goes, Turns, Stops, and even Flies.
1993 Z28: Road Race car - LT1/T56 - SoloSprint #95 - Goes, Blows, Goes and Blows.
1973 Camaro: Dad's - 355, TH350, 4.10's.
1981 Z28: 383 c.i., TH350, 3.42's - sold August, 2000.
Capn Pete is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
