hypothetically..
Old May 14, 2003 | 11:55 AM
sinjin89r/s's Avatar
hypothetically..
hi everyone--
just for grins--what are some ways to modify my 2.8 six-cylinder in my 89 r/s..i am heavily considering doing the LS1 swap in the future but i am just curious as to what can actually be done to give my motor some more pep if i decide not to do the swap..anyone ever tried anything??let me know what your ideas are and if you have any successes..thanks one and all...sinjin 89r/s
Old May 14, 2003 | 02:21 PM
ibanez6rg's Avatar
Basic bolt-ons
Old May 14, 2003 | 03:13 PM
95 3.8's Avatar
add two more cylinders
Old May 14, 2003 | 03:16 PM
95GRNZ's Avatar
Cool
Originally posted by ibanez6rg
Basic bolt-ons
Exactly. It's an engine just like any other one. Whether it is worth it, is up to you, of course.
Check out also C/FBV6.com. There is a section dedicated to 3rd Gen sixers. You might find some help/ideas from there, too.
Good luck!
TS
Old May 14, 2003 | 03:21 PM
Bliggida's Avatar
As far as all out power, its not the answer you are looking for because its so general, but it really truly comes down to how much money you want to spend.
You could have a machine shop bore the cylinders out, use a set of custom forged oversized pistons, forged stroker rods along with a forged stroker crank. Run a minimum of 10:1 compression, unless you plan on running a lot or boost or nitrous - then 8:1.
With the bottom end taken care of, you can either port and polish your stock heads, or have someone custom mill you a set of heads. Install larger valves, stiffer springs. Port match your stock intake. There are a number of cam companies that will make you a custom grind.
Probably the most effective way to gain horsepower in terms of a budget would be to install a complete high performance exhaust. From headers to tips.
Ram air.
Run steep rear gears like 4.10's.
And get Edelbrocks:
Upper intake PN:3785 $238.95,
Lower intake PN:3787 $131.95,
Cam Kit PN: 3790 $182.95
Edelbrock parts Total $553.85
You may be able to use PaceSetter headers made for the 2.8L in an S-10 truck. Then, once you have that, use whatever V8/IROC exhaust you like that is made for your Gen 3 body.
I think you will have spent between 1,000 to 1,500.
Be close 40 extra horsepower when you are done. And if you figure in the gain you get from the 4.10's, that will be like adding another 37 horsepower.
Theoretically you could put down near 175 horsepower normally aspirated. But with 4.10's it'll feel like 212 HP.
With a forged bottom end you could research turbocharging. Running 25 pounds of boost, you could manage into the 300 HP mark.
Or with a 250 shot of nitrous, manage 425 horsepower total when you are engaging it.
A smaller shot would be much more economical though. That's all out racing (above).
You could manage a 50-75 shot on the stock bottom end, for about 300 bucks. So that when you go to race, with the Edelbrock parts, 4.10's exhaust, and ram air. You could manage a respectable 225-250 horsepower. Should be enough to put you into the 14's if your suspension was built to put the power down. But 15's for sure. You'd probably beat most stock 3.8L F-bodies, and just any about any ricer that pulls up along side you.
Old May 14, 2003 | 04:55 PM
95 3.8's Avatar
Good luck!
TS
thats true, thats why I'm looking forward to get an LS1; and Bliggida, I really liked your awser, It makes me think.
Old May 14, 2003 | 05:46 PM
Wolfie's Avatar
swap that 2.8 out for a 3.1,or better yet a 3.4
if you live in an area that dosen't do emission testing the get the edelbrock 4bbl intake(or better yet one of the old offenhuaser 360* equal ports,but you'd have a better chance of finding oil in your yard) and a 390 cfm holley, and a nos squre bore plate system, big cam,port the heads headers from a 4th gen or s truck willl fit,but ether way thell a lil bit of persuasion to fit
basically what biggida said it'll scoot,its not and ls1,but it'll scoot
Old May 15, 2003 | 08:11 AM
stale's Avatar
AhaHaHahaha!
Old May 15, 2003 | 04:36 PM
95 3.8's Avatar
Originally posted by stale
AhaHaHahaha!
thats what they told me first time I asked...
Old May 16, 2003 | 07:58 AM
stale's Avatar
Yeah, I caught flack for asking that question a few years back myself. I did end up finding out all that needs to be done to my '96 3800 in order to drop an LT1 in... forget that! It's so much work that it's not even worth it
Old May 16, 2003 | 10:59 AM
95 3.8's Avatar
same here... I was "dreaming" about that, but like you said, is not worth it. I'll save and get an z28 later on.
Old May 17, 2003 | 03:23 AM
Bliggida's Avatar
an LT1 swap would run you about 1500 dollars.
You can't sell your V6 + 1,500 and equal a Z28.
