Old 05-13-2003, 01:59 PM   #1
u2slo5point0
Rear Window Molding
I would like to replace the trim molding around the base of my rear window. Can this be done without taking the glass out? I really dont want to replace the glass but removing it will most likely break it. Just curious if anyone has done this...
-Tim
u2slo5point0 is offline   Reply With Quote
Old 05-13-2003, 02:02 PM   #2
1997rblckSS
Member
I am curious to, mine looks like total a$$ right now, the dealer tried to repair under warranty with that crap adhesive, and it got worse when I was down in Florida, seems like the heat melted the adhesive, anyways I am curious on this topic also...
TTT
__________________
Rick S
1997 Onyx Black Camaro Super Sport
Car#2167 (1 of 109 black coupe/m6's)
SLP options and some bolt ons.
13.4 @ 104 mph w/2.01 60'
different run:
1/8 mi. 8.4 @ 85.87 w/ 1.8 60'
Member of the Middle Tennessee F-Body Association
1997rblckSS is offline   Reply With Quote
Old 05-13-2003, 11:55 PM   #3
sp528
If you are talking about the "window lace" that goes around the edge of the back window they make a replacement for that. It's GM part #10433037. I got my new one from GMpartsdirect.com for $25.31 shipped. It comes with adhesive already on the strip.
__________________
'95 Trans Am M6: K&N CAI, T/B Bypass, 1LE Elbow, Hypertech 160 Thermo, !AIR, LT4 KM, PCMForless Programming, BMR Strut Brace, Corvette Engine Covers, Coated Pacesetter Shorties, !Cat, Flowmaster Muffler, 1LE Sway Bars, BMR LCAs, Motive 3.73 Gears, Clear Front Turnsignals, '98 Chrome T/A rims, '97+ Console, Passenger Window Express Down Mod, Alpine 200W Headunit
sp528 is offline   Reply With Quote
Old 05-13-2003, 11:56 PM   #4
sp528
Oh, and I live in Florida and so far the heat hasn't done a thing to the new rubber adhesive.
__________________
Old 05-14-2003, 01:28 AM   #5
fbird95
Prominent Member
This is one of those serious GM (General Mistakes) I have seen cars in 02' come of the truck from GM with this problem allready begining. Its BS, i should not go to my local GM dealer and find cars that are almost brand new with a little white t marking a problem on them. I usually see camaros with the top have plain out removed, and firbirds with the corner peice joining the top and bottom window lace looking like real garbage. Almost like they let a 3 year old blind kid try to fix it. This seriously should be a GM quality recall and should not run the owner 24.00 to fix.
fbird95 is offline   Reply With Quote
Old 05-14-2003, 07:59 PM   #6
Terran2k
does this weatherstrip have the L shaped plastic elbow piece that fits on the corner of the rear glass? one of mine is broke and would like to fix it
__________________
1997 A4 mystic teal z28 - slp cai, bmr sfc/stb, tb bypass, ls1 front brakes
Terran2k is offline   Reply With Quote
Old 05-14-2003, 08:06 PM   #7
shoebox
shoebox's Avatar
Quote:
The lace is now a new design and is one piece. No separate "L" piece.
shoebox is offline   Reply With Quote
Old 05-14-2003, 08:09 PM   #8
Terran2k
good, i disliked that "L" piece
__________________
Old 05-14-2003, 08:59 PM   #9
Hyperspeed97z28
Hyperspeed97z28's Avatar
__________________
-Keith
Hyperspeed97z28 is offline   Reply With Quote
Old 05-14-2003, 11:09 PM   #10
ponyackn
Question
Does installing the new strip require anything special? Do you have to remove the window from the hatch or is it a simple method? One more question... I only tore the top half off, right before the L so does it look like the replacement strip can be cut and installed??
Thanks,
daniel
__________________
1996 WS6 HD Edition TA- Black and Supercharged ---->http://rides.webshots.com/video/3087...48387102wGNOOy
1996 Pontiac TA M6- Sold but never forgotten
1986 Pontiac TA - Sold years ago but began the addiction
ponyackn is offline   Reply With Quote
Old 05-14-2003, 11:13 PM   #11
shoebox
shoebox's Avatar
Quote:
Thanks,
daniel
You don't want to cut it or you would ruin half the purpose of it being one piece.
It is just a beauty part. It does no sealing and the window does not have to come off. Pry the old lace off and clean everything up well before you put the new one on.
Old 05-14-2003, 11:14 PM   #12
mobleman
Great post!
Now of course you've brought this back to my attention as being a problem (where I have successfully been ignoring it for years )
I guess I should order the part and get it fixed....
__________________
1995 Z28 Mystic Teal M6 Hardtop. 355, LE2 Heads, 224/230 112 LSA Cam, 30# SVO Injectors, Mac Headers, SLP 2OTL, 1.6 Pro Mags, Comp R Lifters, Elec WP, K&N FIPK Bilstein HDs, 35MM Frnt Sway Bar, 1le susp bushings all around
http://www.cardomain.com/ride/618381
mobleman is offline   Reply With Quote
Old 04-18-2006, 10:43 AM   #13
96_Camaro_B4C
Re: Rear Window Molding
Sorry to drag up an ancient post, but I've had this issue with mine as well. My '96 was originally a California/Arizona car before I bought it, so it likely saw plenty of heat. Anyway, it has oozed adhesive from the lower front corners of the rear hatch/trim interface since I've had it. I always just wiped it away.
Well, lately it has been bothering me, and in a somewhat ill-advised or poorly planned bit of frustration the other day, I started to cut it off, thinking I did not have the new one piece lace that is supposed to fix the problem. I had done a brief search and found a couple of guys who had removed it altogether, and thought that might look sharp. So I started removing, but only got part of it cut off. I realize that I have the single piece lace already (further searching for threads on the topic seems to confirm it; looks like '95-'96 is when the change was made ). Now I'm really pissed at myself, because a) I'm having trouble getting if off; seems to be harder than what has been described about removing the multi-piece lace, and b) I'm not sure I will like the no-trim look against my white car (the gap between the glass and the roof piece is more noticable than it would be on a black car, I think). I should have just dealt with a little oozing now and then; instead I've made more work for myself, when I should be dealing with the plug changes, oil leaks, etc. I have to do to this car.
Has anyone removed the one piece before? It seems to really be on there pretty tightly, so I've been cutting and removing in sections (and getting very sticky hands in the process). Will I have to remove any of the inner trim pieces from inside the hatch to get the rest off? I have the factory service manual for the car, but it seems to reference how to install the trim if you have the glass off the car, which I REALLY hope I don't have to do. I thought this would be a simple cut/pry off the old and attach the new, but apparently the newer 1 piece design is a bit more firmly attached... Like I said, I'd done a little bit of searching, but obviously I need to plan/research a little more carefully before I start half-heartedly messing with things that aren't so bad to begin with...
Any advice. Shoebox? Anyone else who's messed with this?
EDIT: I know this should be in general tech, not LT1 tech, but it's an old thread and that's where it was originally. If a mod wants to move it, that's cool with me.
__________________
Joe
'96 Camaro B4C M6, White, 107k (no police use ever!), K&N FIPK, TB Bypass, Flowmaster, CAGS Elim., ZR1 SS wheels
'05 Colorado LS M5, Silver Birch Metallic, 30k, Z71, 2WD
'04 Yamaha FJR1300, Silver, 11k, 145 hp, heated grips, Yamaha/Corbin seat, silver bullet
96_Camaro_B4C is offline   Reply With Quote
Old 04-18-2006, 12:28 PM   #14
shoebox
shoebox's Avatar
Just pry the old one off. Mine just pulled off without much trouble. I guess most of the old glue had already oozed out. It comes off from the outside without removing the glass.
Old 04-18-2006, 03:48 PM   #15
mfb_lt1birdman
Send a message via AIM to mfb_lt1birdman
Just to be clear on this (btw I have read through many posts on this)
The existing seal/weather strip (multiple pieces) which surrounds the entire hatch has nothing to do with actually sealing the glass? How does the glass seal then? Does this new one piece lace cover the entire hatch surrround? Thanks for making this crystal clear.
__________________
94 T/A -Edelbrock Shorties, Hooker Cat-Back, LFE Cold Air, McLeod Street Twin, Koni SA's, C5 brakes,TB Bypass, 160 tstat, LT4KM, MSD6BTM (no more boost though) MadZ28 tune, Al drive shaft, SLP short throw, !AiR *Dynoed 282 RWHP and 323 RWTQ*
mfb_lt1birdman is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
