Old 05-05-2003, 10:50 PM   #1
CODY BEHNKE
Firebird gauge cluster ?
Will any of the 1997+ clusters work without problems?
CODY BEHNKE is offline   Reply With Quote
Old 03-30-2004, 07:20 AM   #2
Live for TAs
Live for TAs's Avatar
TTT on this, I'm interested in adding a 1997 cluster to my 1995 TA so I can convert to the 200 MPH speedo. Anyone done this or know if it is possible?
__________________
1995 TA Click for mods, home made rear mount, 498 RWHP, 579 RWTQ for now....
Minor Mods, matching TA color scheme: 1998 Durango
1988 Supra Gen 3 V8 swap underway!
1978 280Z LT1/T56 swap
1966 Corvair Corsa
Live for TAs is offline   Reply With Quote
Old 04-22-2004, 06:44 PM   #3
99TransAmWS6
Send a message via AIM to 99TransAmWS6
Cody Check your PMS
99TransAmWS6 is offline   Reply With Quote
Old 04-23-2004, 12:42 AM   #4
craigffb
Send a message via ICQ to craigffb
Yes a 97 cluster will work in an older car. I have one. I have a 94 and the only problems I have are the TCS light stays (I don't have TCS) on and the seat belt indicator does not go all the way out when I put my seat belt on, it just dims a bit. But it must be out of a 97, an LS1 cluster will not work.
__________________
1994 Ram Air Formula A4
2007 Grand Prix GXP
2005 GTO1999 Sunfire GT
craigffb is offline   Reply With Quote
Old 01-04-2009, 04:47 PM   #5
marc1130
Quote:
I have the same problem with the seatbelt light. Is there any fix, I'm thinking it is because diodes are used instead of lightbulbs and there is a BCM in the 97 model, where as we have an audio alarm module
marc1130 is offline   Reply With Quote
Old 01-04-2009, 05:01 PM   #6
craigffb
Quote:
Not that I know of. I've had mine in my car long enough I don't even pay any attention to it any more. I did cover the TCS light spot with a piece of electrical tap, so it doesn't show anymore.
__________________
2007 Grand Prix GXP
Old 01-04-2009, 11:55 PM   #7
IPrice
Premium Member
Why don't you guys remove the cluster and take the light bulb out that makes this useless reminder go away for good????
That's (not) what Brian Boitano would do.
-Ivan
__________________
'96 Z28 M6 Recently signed over to the Boy
'95 Z28 A4
'67 Camaro 327ci
IPrice is offline   Reply With Quote
Old 01-05-2009, 12:03 AM   #8
neil350
Send a message via AIM to neil350
1994-1996 can use the 97 clusters, 93s are screwed like always, the tach wont work past 2K rpm.
__________________
93 T/A l LME Dart Pro 1s + "CC306" + N20 l Full Bolts Ons l Lots of Suspension l LS1 Brakes l A4 w/ Vigi 3200 l 3.73s l Fikse Mags l Firehawk hood
08 GMC Sierra Ext Cab 5.3 - Stock
neil350 is offline   Reply With Quote
Old 01-05-2009, 12:05 AM   #9
craigffb
-Ivan
They aren't bulbs. They are diodes soldered to the board.
__________________
2007 Grand Prix GXP
Old 01-05-2009, 12:07 AM   #10
Gtpguy
What happens to the mileage? Does the 97 gauge cluster (digital ode) read it from the PCM?
__________________
1989 Red GTA: 350TPI / auto / 3.27
Gtpguy is offline   Reply With Quote
Old 01-05-2009, 12:10 AM   #11
craigffb
Quote:
Mileage is stored in the cluster. Find something close or get it reprogrammed. Not sure who can do it.
__________________
2007 Grand Prix GXP
Old 01-05-2009, 01:04 AM   #12
marc1130
-Ivan
Yeah I'd have to tape it off, it's an LED, which is why I think it stay's on. I'm getting this idea that the older bulb versions send two 12volt signals in opposite current directions to shut off the bulb. With the LED it is biased in one direction therefore it is always on.
Theoretically 96 cars should not have this problem because they use the Body Control Module rather than the Audio Alarm Module to control the seat belt indicator.
I was thinking of taking the spare '97 v6 gauge cluster board I have laying around and soldering a bulb in place of the LED to see if it fixes the problem, if that works I will modify my '97 155mph v8 cluster.
Another fix would be to rewire the interior to accept the body control module from the later 96-97 f-bodies, not worth the effort.
Old 01-05-2009, 08:35 AM   #13
MTBSully
Send a message via AIM to MTBSully
good idea. I have had two 95s before this and the 97 dash looks 10x better then the dashes of previous years.
__________________
97 WS6
383 11:1, Eagle crank, speedpro pistons and rings, LE2 heads, XE 230/236 Cam, Ported intake, CC 1.6 NSA rockers, Hooker Longtubes, Mufflex O/R Y and 4" catback, 30LB SVO's, PCMFORLESS OBD-1 conversion, TR55s, Taylor OTCV 8mm plug wires, Hurst Short Throw, Edelbrock 3 pt strut tower brace, Edelbrock SFC's, 8pt Cage and Buckets
MTBSully is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
