07-15-2002, 11:13 PM
Member
Changing plugs and wires = battery melting along with pos and neg cables WTF??
AS it says i'm so fumed i cant begin to talk except i was gled no fire was started or anyone was hurt. I was changing plugs and wires. This process took me about 3 hours. When i started i dissconnected the neg cable on the battery.
I'm all done i begin to put cable on and i got it started nothing happing, when i'm about half way on somthing in pass eng comparment started sparking and i began loosing asap well i didnt make it the negtive terman malted off the battery. Both wires are toasted.
WTF
before i end there are 2 varibles that are different, 1st the oil dipstick was loose i moved it slightly to get in and i did not tightin it fully, secondly there was a socket that droped in the eng comp, i was attenpting to back it out to find it in the daylight.
So what you all think and any rough estimate how much it is to fix ?
DO YOU THINK THE PCM OR ANY VITLES WERE BRUNT DURING THIS THE CAR WAS IN THE OFF POSITION WHEN I RECONNECTED THE BATTRTY NOTHING CAME ON.
DONE VENTING
2000 Pontiac Firebird Trans Am A4 w/3.23
MODS: the free stuff, FRTA, LID, HPP3, CUT-OUT, and An assortment of tires
Best stock ET: 13.60 @ 103.4
BEST ET: 13.1 @ 105
MI Plate: BAD2KTA
The muscle car lives...
2001 GMC Jimmy 2 Door 2WD
__________________
BEST ET: 13.1 @ 105
MI Plate: BAD2KTA
07-16-2002, 05:41 AM
I'd bet that the socket that you dropped didn't fall all the way to the floor but instead landed on top of the battery lead on top of the starter. When you went to hook things back up..direct short.
Jack her up and pull the starter. I'll bet the socket is right there. Probably welded to the cable.
Should be a case of just changing out the burnt wires and battery.
good luck,
Al
Blue Green Chameleon 2000 Formula
Hardtop, A4, 3.23
Yank ST3500, TransGo, & cooler
FRA, Direct Flo/K&N, EGR bobbitt,
!TB coolant, Just Me Thermo mod
SLP resonator exhaust, ES tranny mount
Home Boxed LCAs/ES bushings, LCA relocators
Best 60' 1.762
Best 1/8 8.106 @ 86.45
Best 1/4 12.704 @ 106.68
Best Mph 109.72 with a tail wind
and her
Black '98 SS# 590 M6
T-tops, Leather, Loaded
07-16-2002, 06:30 PM
exactly what I was thinking. no other possibilities really. replace pos. and neg. batt. cables, posts, and batt. and you'll prolly be all set.
other poss.s of things gone wrong are burned fuses and fusible links at starter. give each wire a tug (lightly) to see if the fusible links are good at the starter.
chris
__________________
FOR SALE1995 z28, 8x,000 miles on car, fresh trans with shift kit, 40Kmiles on stock short block, just freshened up (some bearings, seals, cleaned, reassembled, painted), ported heads, ported intake, A4, white, 17" budnik's, graphite leather interior, tints, loaded, SS hood, "RS" spoiler http://creimer.myphotoalbum.com/
07-20-2002, 05:43 AM
Well did ya get it fixed?
What was the problem?
Inquireing minds want to know
Al
07-20-2002, 12:07 PM
Take it to the dealer,it is still under warranty?
Tell them you went to start it,and it started to smoke.
How are they going to know what happened.
__________________
2001 3.8L Firebird W68 Y87 C6 Rims
07-20-2002, 11:20 PM
Al, my fellow Formula freind, you hit the nail right on the head. Upon further investigation, the culprit, a socket wrench, lay on top of the starter. I couldnt tell you exactly how/what happened because i wasnt there during the maylay, but I got a shocking voice mail while i was out of town at the time "ooooooooooooooooooo SHIIIIIIIIITTTT!!!!"
John
Bright Red 2002 Pontiac Firebird Formula M6
taupe leather - ttops - 6 speed
1995 Quasarblue Z28 hardtop A4 - sold
Motown Muscle a Detroit area performance club for today's musclecar
__________________
John
2002 Formula NASA Time Trial
2000 Formula NASA American Iron
2008 Ram Sport
07-21-2002, 08:35 PM
Member
as quasar said it was the ratchet that caused this.
The car is at the shop awaiting a list of things to be done, final danage report is
new bettery, neg and pos cable and handful of fuses.
__________________
BEST ET: 13.1 @ 105
MI Plate: BAD2KTA
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
