Old 07-23-2002, 10:29 PM   #1
firstgen
Post Paging all Michigan drag racers and close by!
Milan Dragway!
The Eastern Michigan Camaro club has the track rented this Monday July 29th. Gates open at 6:30pm and we run from 7pm thru 10pm.
Each car running will cost $30 or less (Depending on turnout) and spectators are free.
Last few times we had like 25 or less cars, and there is no wait to run so you can run as many runs as you want. It's a fun time plus great for tuning and testing.
I'm inviting you all you're all Welcome no matter what you drive.
Hope to see you all there!
1967 Camaro SS - 468 BBC modified
1967 Camaro RS - 327 stock
1969 Camaro Z/28 - DZ302 stock
2000 Ducati 996
Member of the Eastern Michigan Camaro Club
__________________
1967 Camaro SS - 540cu Merlin II
1969 Camaro x11 Yenko clone - 572cu Dart Big 'M' (work in progress)
2000 Ducati 996
2003 Mercury Marauder 300B
firstgen is offline   Reply With Quote
Old 07-23-2002, 11:35 PM   #2
taner
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
will they prep the track?
normally the traction is not very good there?
thanks
taner
__________________
1996 Camaro SS Harshaw Racing Engines 396 m6 FULL BMR suspension
Best 60': 1.277 Best mph:151.84 mph Best N/A Mph: 131.xx mph
9.08@155.07mph N2O 1.425 60'/ 10.54@129.28mph,NA 1.497 60'
Quickest and Fastest m6 F Body, 1st LT1 m6 in the 9's. 1st m6 F body to crack 150 mph.
taner is offline   Reply With Quote
Old 07-24-2002, 01:23 AM   #3
firstgen
Talking
I'm sure we can get them to prep it. I was spinning off the line last time out but I think it was more of a weight transfer to the rear problem then anything. I'll soon know this time out. New springs and shocks this time around and bigger fuel line with new pump.
2000 Ducati 996
__________________
2000 Ducati 996
Old 07-24-2002, 09:41 AM   #4
jp2002ls1
Sweet, I will definately try to be there in my 2002 Z28, I usually go on Wednesdays or Fridays and it is always busy there, usually only get 5 runs the whole time they are open on Wednesdays. It also usually costs $20 to race so $30 ain't bad as long as you can get a lot of runs. The track does suck for traction though, I can never get my car to hook up there. Hope to see you guys there!
__________________
Attorney at Law
All toys sold to fund my law practice.
Former toys: Modded Corvette, 2002 Z28, 1994 Z28, 1994 Lightning, 1971 Cougar, 4X4's, more...
jp2002ls1 is offline   Reply With Quote
Old 07-26-2002, 02:58 PM   #5
97 6SPEED Z
Question
I know you mentioned that spectators are free, so if I can't get the Z ready to test and tune by Monday, can I just drive up and watch for free or are they charging every CAR that comes in?
'97 LT1, MN6, !CAGS, Throttle Body By Pass, 160F Thermostat, Pro 5.0 shifter, BMR Shock Tower Brace, BMR Sub Frame Connectors, 3" Super Turbo Cat Back, Moroso CAI, and SLP Airfoil, LT4 KM, Pacesetter shorty headers, Nitto 315/35/17 drag radials, ASP 34% underdrive crank pulley, Comp Cams XE 230/236 cam and 1.6 to 1 ratio roller rockers, OBD1 conversion PCM, de-screened MAF. Best 1/4 mile pass,(so far),13.060 @ 109.53 with 2.287 60ft time.
__________________
'97 LT1, MN6, 52mm TB and 30lb/hr SVO injectors, 160F Thermostat, Pro 5.0 shifter, BMR Shock Tower Brace, BMR Sub Frame Connectors, 3" Cat Back w/ Cutout and Flowmaster 50 Series muffler, Moroso CAI, and SLP Airfoil, LT4 KM, shorty headers, MT 26.0X11.50X16 ET Streets, ASP 34% underdrive crank pulley, Comp Cams XE 230/236 cam and 1.6 roller rockers, OBD1 conversion PCM, de-screened MAF, 4.10 rear gears, Harlan shiftlight and Summit line lock. Best 1/4 mile pass,(so far),12.210 @ 115.42.
97 6SPEED Z is offline   Reply With Quote
Old 07-26-2002, 03:27 PM   #6
firstgen
You can drive up and watch for free.
2000 Ducati 996
__________________
2000 Ducati 996
Old 07-29-2002, 09:06 PM   #7
taner
is there a rain date?
thanks
__________________
Old 07-30-2002, 05:11 AM   #8
firstgen
Talking
I'll post it as soon as I find out.
2000 Ducati 996
__________________
2000 Ducati 996
Old 08-05-2002, 03:41 PM   #9
97 6SPEED Z
Was there ever a rain date set for this? Thanks
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
