Old 07-28-2002, 12:14 AM   #1
jd13
Send a message via AIM to jd13
Post 1/8 times
Ran the 1/8 (only thing close) the other night. Ran a few 9.3s when the sun was up. Temp was lower 90s with about %80 humidity. Sun went down, was still upper 80s though. Here's my best run of the night.
R/T: .812
60': 2.170
330: 5.980
1/8: 9.177
MPH: 76.35
I don't think that's too bad for a near stock 1990 350. Someone said that would put me at low 14s and possibly high 13s. I dunno about that. Any idea what that would come out to in the 1/4?
__________________
Seriously?
jd13 is offline   Reply With Quote
Old 07-28-2002, 10:36 AM   #2
CANTONRACER
CANTONRACER's Avatar
14.3's@97-98 MPH.
1996 Z28 Camaro
2001 best 1/4 BFG DR's NA - 11.865@113.57 w/1.634 60', 1/8 - 7.563@89.82mph Best 1/4 MPH 114.82 - Best 1/8 MPH 90.73 - 2002 Mid 11's NA, Mid 10's n2o
1989 GMC 1500 truck for work 18.1@73 305
8 cats to feed clean after 1999 V6 Mustang 5 speed
15.358@89.47 MPH w/ 2.227 60'
15.364@90.92 MPH w/ 2.383 60'
__________________
1996 Camaro Z28
1999 Mustang Coupe
2006 Mustang GT "Glassback"
2008 Escape
CANTONRACER is offline   Reply With Quote
Old 07-30-2002, 06:37 AM   #3
StreetStang37
Member
from info from other runs by other people, those 1/8th mi. times come to:
14.11 @ 95.98
just an estimate, could always use more info.
1993 Grabber Blue Mustang GT
"Bolt-On's" (no power adder(s)
13.007 @ 108.39 w/ 2.149 60'
__________________
12.96 @ 109.78 w/ 2.176 60' w/slipping clutch
StreetStang37 is offline   Reply With Quote
Old 07-30-2002, 11:35 AM   #4
CANTONRACER
My Z28 ran stock,
60' - 2.139 (but I did get a couple of 2.06's in there)
330' - 5.929
660' - 9.097@77.99 MPH
1320'- 14.085@99.16 MPH
To run a 1/4 @ 14.11@95.98 MPH with a 1/8 @ 9.177@76.35 MPH would mean you would get (1/4)/(1/8) of 1.538, which is what cars with very strong topend charge get. Those year 350's were low end cars. If you say his 1/4 MPH would be 101-102, then it might pull it off then.
But none the less, a good running car.
1996 Z28 Camaro
__________________
1996 Camaro Z28
1999 Mustang Coupe
2008 Escape
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
