HAL QA1 install
Old Jul 19, 2002 | 07:25 AM
MislMan's Avatar
Post HAL QA1 install
Fixing to install HAL shocks on the front using HAL springs. I have done a search on this as well as looked at a couple of other sites with no clear answer. What I need to know is what is required to be installed on the top of the HAL shock rod when installing using their springs? Can you just slide the rod up through the stock mounting plate or do you have to place a spacer of some sort on the rod before the install? The instructions are not very clear on this and HAL doesn't answer my emails. The stock dust boot does not fit over the rod nor inside the springs. Any help would be appreciated, pictures would be even better.
Thanks!
Later ... Larry S.
'95 Trans Am - Powerdyne
11.874 @ 118.92 MPH
Old Jul 19, 2002 | 11:41 AM
Grover's Avatar
Forget the dust boot and use the factory upper mount.
Chad Beebe
'97 T/A WS6 M6 Dark Metallic Green
CC 306 cam and some other stuff.
My Car
12.762@109.13 with 1.828 60'
Best 60' 1.816
Nov 18, 2023 07:21 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Victory Racing
Apr 19, 2010 06:08 PM
