Old 04-25-2003, 12:57 AM   #1
chevycamaro1995
Junior Member
hurst quarterstick in my Z28?
I know that Hurst or any other company doesnt make a shifter for an A4 LT1 car. Unless theres something else out there... I wanted to try to rig up a 700R4 version of the quartestick to my 4L60E. Do you think it will work? Come on... It only selects the gears right?By the Way... I have a 1995 Z28.
chevycamaro1995 is offline   Reply With Quote
Old 10-02-2005, 09:22 PM   #2
cpt_bimes
Re: hurst quarterstick in my Z28?
yeah it will work. You'll have to get creative on making the shifter look good.
__________________
'02 Z28 M6 Just bought it 08/07
'96 Z28SS #540 A4, Yank SS3600, 3.73's, Manifolds, MADWolf tune, NX 75 Wet, Cutout
Motor 60ft-- 1.744 1/8-- 8.34@81.05 1/4--13.22@100.9
Squeeze 60ft-- 1.567 1/8-- 7.56@88.39 1/4-- 12.05@109
I pull the wheel sounding like a farm truck.
cpt_bimes is offline   Reply With Quote
Old 10-03-2005, 02:46 AM   #3
revtime
Pick up a B&M Pro Stick. You can purchase a gate plate for a 4 speed auto.
I was afraid to do this for years but recently installed one, its no big deal.
You will have to custom mount the shifter, you will lose the "step on brake to shift from park" crap and there is another cable that keeps the steering wheel from locking unless the car is in park, so without the cable hooked up the steering wheel WILL lock if the key is turned to the off position, even if your rolling down the highway. so keep it in mind. Wiring is not too bad. B&M has a backup light switch you can order seperately and it comes with a nuetral safety switch. For now I connected the nuetral safety wires together and left the backup lights unhooked, the other 2 wires in that bundle are for your remote hatch release. Car has to be in park or nuetral for the hatch release to work, I just use the key.
Honestly, mounting the shifter is the hardest part. Getting it to work with your stock console can be very tricky. I took the easy way out and chopped the middle out of my console, its a hack job and it looks like it too.
__________________
94 Z28 A3
Direct Port, TH400, 12 bolt.
Scattered block coming soon.
revtime is offline   Reply With Quote
Old 10-03-2005, 11:00 AM   #4
cpt_bimes
This is how i made my buddies console look. He had the shifter mounted, i just cleaned up the console and mounted the Transbrake button.
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
