Sound system idea. Is this do-able?
Old Apr 7, 2003 | 05:11 PM
bandit1's Avatar
Question Sound system idea. Is this do-able?
Okay, I have a 96 TA. I want to add a little punch to my stock system. I currently have the 200 watt 8 speaker system w/ the rear CD changer, tape deck, and steering wheel controls. Here is what i have in mind.
Move the diskchanger to the middle glove box. If it doesn't fit buy an aftermarket and use that. Put a 10/12 sub in the back left corner panel, use the stealth box. Put the amp where my spare tire used to be. Here the trouble spot.... I want to keep my steering wheel controls functional. If I change the deck is this possible? I don't know much about car audio, but I'm pretty sure I can use the factory deck w/ the sub and such. I would really like to get a new head unit though. What are my options? Any input is appreciatied!
Thanks,
Mike
Old Apr 7, 2003 | 11:03 PM
firebirdude's Avatar
Visit www.ls1.com cn click on the "electronics" forum. Check out the FAQ tread at the top in blue writing. That should answer all your questions.
Old Apr 8, 2003 | 12:56 AM
RallyRedTexan's Avatar
Very do-able, but you'll need some converters go read^^^.
You'll have more luck getting the changer in the other glove box. It will need to be a custom fiberglass/MDF job more than likely.
Old Apr 8, 2003 | 08:36 AM
bandit1's Avatar
Thanks for your help! I will check it out ASAP. I noticed one of you sell stealth boxes for 2 bills. Does that include shipping?
Thanks again,
Mike
Old Apr 8, 2003 | 09:54 AM
stik6shift98's Avatar
i got my10 inch sub and stealthbox...mtx for 170 brand new shipped to my door
Old Apr 8, 2003 | 12:26 PM
Thanks again,
Mike
Are you talking about www.subthump.com
Old Apr 8, 2003 | 05:55 PM
Nope he's talking about my used boxes for 12" with 1.0 cu ft volume. Much easier to run a W3V2 or Type-R when you have the correct volume.
Old Apr 10, 2003 | 10:23 AM
bandit1's Avatar
Thanks for the input fellas. I'm trying to get my sheot together. I might be picking your branis and asking for ideas later.
Thanks again,
Mike
Old Apr 10, 2003 | 04:57 PM
I reread your post. You'll get the biggest increase in listening pleasure from adding a new head unit and a sub/amp combo. Might as well get the head unit if you're just gonna have to spend nearly $100 on a converter anyway. Post up with anymore questions.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
formula79
Aug 24, 2002 12:02 PM
CamaroZBoy
Aug 16, 2002 10:03 PM
