Driveshaft length with a 9" rear?
Old Apr 2, 2003 | 03:43 AM
Jim S. '95 Z28's Avatar
When running a 9", does the driveshaft need to be shortened? I know this is the case with a 12-bolt.
I'm hoping a driveshaft 3/4" shorter than stock will work with a 9"
Old Apr 2, 2003 | 09:15 AM
EddieP's Avatar
Re: Driveshaft length with a 9" rear?
I've done two 9" installs in my f-bodies, and the stocker was the correct length both times. There are two different pinion yokes for the 9" diff, though - a short and a long one. The short yoke fits perfect for the stock length driveshaft. Maybe try the long yoke? Not sure the length difference between the two, but I think it's around 1" longer.... that would get you close. Call Moser up - they'll definitely have the answers.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 31, 2015 10:58 AM
redleader
Jan 22, 2015 12:05 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
