Anyone running Hoosier Quick Times...?'s inside
Old Mar 30, 2003 | 08:40 PM
RedHotTA's Avatar
anyone running a hoosier quick time pro DOT or something similar (26x9.5)...if so what kinda air pressure are u running, how big of a burnout, avg. 60', and what kinda ET are u running and what MPH are you trapping?...im just trying to find out a good starting point, thanks guys
Old Mar 30, 2003 | 10:58 PM
RacinLT1's Avatar
i run the QTP dot in the 27x11.5x15 size.
Air pressure is usually around 14,or i will go down to 12 for a bad track.
Burnout till i see smoke then rollout,unless the track is fresh,then i smoke the crap outta em.
12.38@108 is n/a......average 1.67 60'.
Nitrous is 11.25@119 average 60' of 1.52
Old Mar 31, 2003 | 11:27 AM
RedHotTA's Avatar
Thanks Dirk...i just finished bleeding the brakes from my line lock install so this week i'll def. be able to heat'em up enough...anybody else runnin the QT Dot? just wondering how u guys like'em cuz i always ran BFG DR's before so this is my first bias ply tire
BTW~~ Dirk, dont know if u remember me but i was at ATCO last december w/u guys...had my 3rd gen there, black 91 firebird...maybe i'll see u again or sometime...later
Old Mar 31, 2003 | 11:54 AM
rje's Avatar
rje
I run the 27x11.5x15 QTP's and IMHO there all over the MT et streets. I do a burnout untill I see good smoke off of both tires, and I usually cut mid 1.5 60fts.
Randy
Old Mar 31, 2003 | 06:57 PM
91rs383's Avatar
Thumbs up
i had a set of 26-9.5-15 QTP's last season and loved them. i did some jumping around on air pressures and found it to hook best with 14 psi and a good burnout. pulled best of 1.67 60' and 11.86 in the 1/4. hope this helps.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Feb 28, 2015 12:02 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
squarehead
Nov 21, 2014 08:02 PM
