[Electronics/Car Audio] Usb?
Old Jul 22, 2008 | 11:06 PM
summerkc's Avatar
Usb?
In the specs it says it has "usb connectivity". Does anyone know what this means? Could it mean you will be able to hook up your ipod and control it through the stereo buttons? That would be freaking awesome.
Old Jul 23, 2008 | 12:50 AM
BitchinCamaro's Avatar
Originally Posted by Gm Chat
BitchinCamaro: What models is the USB port available on, and is it just for iPods?
JohnFitzpatrick: I believe any jump drive can fit in the USB. It will have to have MP3 files to be read, however.
You probably won't be able to use an iPod, since they are AAC files. Maybe if you load your iPod in 'disk mode.'
Old Jul 23, 2008 | 09:14 AM
summerkc's Avatar
Did they say anything about just a normal 3.5mm stereo plug anywhere?
Old Jul 23, 2008 | 12:14 PM
diarmadhi's Avatar
Yes, in the storage area of the arm rest console there is an aux 3.5mm jack.
Old Aug 5, 2008 | 01:33 AM
Kevin L's Avatar
Have you not heard of iPods being called an mp3 player? They also use mp3 compression so yes, you could use one theoretically.
Old Dec 22, 2008 | 10:18 AM
camaroguy579's Avatar
Cars with USB all use iPods. I mean think about it, they don't put it in there just to play music off a flash drive.....iPod is the reason for the usb connection...
Old Mar 23, 2009 | 07:59 PM
prophet33's Avatar
im pretty sure its an extra cost i do believe like 500 for usb n extra odd stuff for it wasnt payin it but i dont know if its free for a higher end model havent looked i would like it though
Old Apr 10, 2009 | 01:20 PM
TransAmHitman's Avatar
Actually that is one of the designs, it should be able to play mp3's straigt from a flash drive, ipod maybe, since it does aac, same with Zune, since that is wma, guess i need to do some more research myself on it.
Old Apr 23, 2009 | 10:51 AM
Rob V's Avatar
The USB port is in the glove box. It will work with iPod, Zune, flash memory sticks and most MP3 players. They can be controlled from the steering wheel audio controls too. Portable hard drives aren't reccomended but it's possible they would work too if in FAT32 format. It can also sync from your blackberry through bluetooth and play music from there.
Old Apr 23, 2009 | 05:18 PM
JasonD's Avatar
Admin Emeritus
For those who haven't seen it yet, here is a GREAT shot of what the USB/3.5mm jack looks like and where it is located in the center console:
Old Apr 23, 2009 | 05:43 PM
CamaroScotty's Avatar
Member
Standard on the 2LT and 2SS - OPTIONAL on the 1LT
(Not on the 1LS or 1SS)
Old Apr 25, 2009 | 09:03 AM
HuJass's Avatar
It will not synch up with Palm Pilots.
I tried.
Old Apr 25, 2009 | 05:56 PM
Chevycobb's Avatar
that really annoys me
PFYC
Aug 24, 2015 06:41 AM
MichiganSkip
May 27, 2015 06:50 PM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
ibanez6rg
Jan 19, 2004 05:22 PM
