Could we get a PS with Targa top?
Old Oct 9, 2007 | 12:18 PM
Tricked-Out-Toy's Avatar
Ok I know there are a TON of talented Photo Shop ppl on here but I havent seen one with a Targa top yet. Since its been confirmed there will be a B-pillar it will deffinetly be a possibility for the aftermarket.
I personally would seriously consider doing the conversion but I want to see what it looks like first as well as making sure the structure is still reinforced.
Theres a company that speciallizes in Corvette stuff and they have been doing the Tarag top conversion on the C6 Z06's and its looks absolutely perfect, like it was factory. and they say the structual reinforcment brings the chassis rigidity back to stock specs......
Old Oct 9, 2007 | 12:38 PM
Rampant's Avatar
look around, I did one a while ago.
No B-pillar though.
found it....
http://web.camaross.com/forums/showp...8&postcount=46
Old Oct 9, 2007 | 12:43 PM
Ya Ive seen that one, but I wanted something thats more "factory" with the B-pillar. that one just looks funny....
Old Oct 9, 2007 | 03:38 PM
Rampant's Avatar
Honestly, I don't quite get everyone's obsession with the B-pillar. It doesn't make that much of a difference.
Targa tops look odd with or without the B-pillar, just as the coupe looks great with or without it.
Old Oct 9, 2007 | 06:32 PM
jg95z28's Avatar
If you're looking for a targa or t-top, your best bet will be to wait for the aftermarket to create a hardtop for the convertible.
Old Oct 10, 2007 | 08:56 AM
JeremyNYR's Avatar
The reason that a targa conversion on a C6 can look perfect and factory is that they're undoubtedly using factory parts! It's incredibly doubtful that any company will design and perform targa conversions for the brand new 5th gen.
Here are my reasons:
1- incredibly expensive R&D work.
2- major liability if problems occur and brand new vehicles are damaged.
3- very limited interest in a major modification to a brand new vehicle.
4- The price to the customer will be very high, especially considering the car payments they're making on their new Camaro.
Old Oct 10, 2007 | 01:31 PM
Rampant's Avatar
^ These guys will probably do it:
http://www.jmsproductsinc.com/homepage.html
They did it for the new Mustang, why not the Camaro? They have the parts (latches, etc.), just an issue of fitting it to the car.
Old Oct 11, 2007 | 08:19 AM
JeremyNYR's Avatar
while the pictures are impressive, this is the first line of text on their site:
"As of 1/1/2007 JMS Products Inc. / Ironman Custom will be formerly ceasing normal operations."
I'll assume they meant "formally", rather than "formerly". I'll also assume that they won't be working on a Camaro Targa any time soon.
The Mustang one does make me like the concept more though having seen an actual targa created for a vehicle that wasn't designed with one in mind.
Old Oct 12, 2007 | 12:41 PM
This place http://www.caravaggiocorvettes.com/dev2007/home.html had to do ALOT of R&D on the C6 and NO they didnt use off the shelf Parts. the chassis stiffening was the most difficult for them and they do say in there article in the Dec 07 issue of Corvette magizine that it was costly but in the end they retain the same rigidity as the stock C6 Z06.
could you do a chop of this car? I Want to see it from more than one angle.
Old Oct 12, 2007 | 05:25 PM
jg95z28's Avatar
Which is why I suggested basing it off the convertible... no chassis stiffening required. I'm sure someone will come up with a hardtop conversion for the convertible at some point. Modifying that into a targa top shouldn't be too much of a stretch.
Old Oct 12, 2007 | 06:13 PM
Thats interesting..... You could have a full vert or drop on your hard top and then pull out the taga and have the best of all the worlds... BUT if I had a vert I dont think I would even bother with a Targa.....
Old Oct 13, 2007 | 04:05 PM
Chevycobb's Avatar
I just dont like the way a targa looks on the 5th gen. it makes it look weird becauseit just leaves you with this awning type look over the back seat that doesn't fit the car well at all. If the camaro was a two seater, like a vette, it would be more fitting. If they offer it thats cool, but i'll stick with the hard top
Old Oct 15, 2007 | 10:41 AM
jg95z28's Avatar
Oh I agree 100%. I also think t-tops would look stupid on this Camaro. About the only thing I might consider is a tonneau cover that hides the back seats on the convertible. (With molded fins behind the front seatbacks.)
Old Oct 16, 2007 | 09:35 PM
Fbodfather's Avatar
ALMIGHTY MEMBER
There will be no Targa -- for a very simple reason:
You would have to be about 7 feet in height and have very strong muscles to put it on and take it off!
The Corvette is lower to the ground and quite a bit narrower -- the sheer mass of a targa top for a Camaro would be 'unwieldy' at best.
Example: (and some of you witnessed this....) I had a Pre-production C6 at Atlanta Gathering a few years ago -- the roof panel was off.....a storm was brewing -- and I went to reinstall the roof panel. It was extremely hot from sitting in the sun -- and as I was talking to someone, the panel 'got away from me' -- a combination of weight -- the hot surface (burning!) and wind (which was getting quite gusty) -- and sure 'nuff -- the alignment post hit the edge of the windshield molding -- and we watched in horror as the windshield cracked the whole way across ---------
It wasn't one of my finer hours...........
Old Oct 17, 2007 | 02:47 AM
SSRich's Avatar
Fbod father i believe i can get stretched and start working out we need something instead of a coupe and a conv. and not a hardtop conv. i couldnt afford 10k for it maybe is T-tops still a option now since its going to have a B pillar.
