Pressure Washer ?
Pressure Washer ?
Hey I was looking into getting a pressure washer for upcoming spring. I want something with alot of power but not so much that it may hurt or damage the paint. Basically I want to know how much PSI and what brand to look for. I'm looking to spend around $150-200. Thanks
-Brian
'95 Silver TA w/ t-tops
!CAGS, 160 degree thermo, Ligenfelter CAI, new SLP take-off shocks/springs, more to come.... Sound system with: Sony Deck, JBL and Lightning Audio amps, Diamond M5 sub, and MB Quart rears and fronts.
-Brian
Don't even waste your money.. All you need is Z6, a water hose, and a decent sponge(preferrably 100% cotton!!)
JackZ28.com
Founding member of FbodyEurope
JackZ28.com
I have a small Campbell Hausfeld electric pressure washer. The sticker on the side says 1300 psi. It's a nice little washer but I find that I can do just as good a job on the car with a regular hose and not have to drag the thing all out and set it up. They are good at blasting off most of the mud and stuff in the wheel wells etc. so they can make that part of the job a little easier. I do find it useful for some other things around the house too so you should be able to find more uses for it.
1996 Z28 Polo Green. K&N CAI, BMR STB, BMR LCA's, SLP B/O SFC's, KVR Rotors, KVR brake pads.
Thanks for all the info. guys! Looks like I'll stay away from a pressure washer and put the money towards Zaino and mods!
-Brian
-Brian
Re: Pressure Washer ?
Power ***** ***** 1700 PSI El***tric Press***re Washer ***GPM with Quiet Induction Motor is the best electric pressure washer brand-spam link destroyed known to me so far.. It has two built-in soap tanks provide convenient storage for the ability to use soap in cleaning applications as needed. It has a good length hose and power cord.It's light easy to use and does the job
Get a real job!!!
14
08-11-2015 12:03 PM
