ABS sensor 94 Firebird formula...
Re: ABS sensor 94 Firebird formula...
Originally Posted by 194bird
wich one
you will have to get it read there is 1 in the rear and 2 in the front and you also have the pump it can couse the light to come on just find out what you need and let me know i have a compleete system even the lines from my 94
there is also an abs module under the dash that is the one that went out in my 97
you don't need ABS anyway just delete it and take all that **** out of you car it clears out a lot of room out from under the hood and it's not a bad weight reduction.
if you deside you "have to" have your ABS get back with me when you figure out what you need i have several cars i'm parting out and i'm sure i will have what you need
thanks
robbie
thanks
robbie
thanks
robbie
thanks
robbie
there is that complete abs control module under the hood next to the air filter
that thing is a good 10lbs
and even better it's off the front tires
i hope you get it figured out
thanks
robbie
P.S.
another thing you could do is get the street in front of your house nice and wet if it's blacktop and just drive at about 10mph and slam on the brakes in the wet patch (make it a few feet from the curb) and have a few friends tell you what tires lockup
if it is all of them it is probly the thing under the dash or the thing under the hood if it is just one of the fronts or both the rears it is probly one of the abs sensors there is one on each front spendel and one in the rear
thanks
robbie
thanks
robbie
P.S.
thanks
robbie
carguyshu
01-22-2017 11:19 AM
jj_burchiel
03-21-2015 12:51 AM
squarehead
01-15-2015 07:02 PM
