Relisting turbo kit
Relisting turbo kit
LT1 Hotparts and a JGS wastegate for sale. A quick rundown of the specs of the hotparts:
stock LT1 cast manifolds
2.5" mild steel cross over pipe
3" DP with wastegate dump
Comes with JGS 40mm wastegate with I THINK a 6psi spring
I built most of this kit almost a year ago and finished the wastegate portion 4 months ago. The person I built it for cant seem to come up with the money for the remaining balance. I am going to see this kit outright so I can give him back his deposit.
This is a race type setup. You loose your A/C and you will have to stand the radiator up vertical and go with different fans.
EDIT**** Ohio Forced Inductions sells an LS1/LT1 radiator that stands up vertical and fits under the stock radiator support ... NO CUTTING************
This setup should have no problem supporting 600rwhp with a T76 and built motor, and I wouldnt be surprised if you saw 700rwhp with an M6 tranny. You may have to make a dent on the DP where it passes by the steering shaft. You will probably have to delete your oil cooler and plug the hole on the water pump. If you dont want to plug the hole, leave the nipple in, slip on a short piece of hose and plug the other side with a bolt or something. Here are some pics of the build. I am making a jig this weekend to pressure test it for leaks and grind down some welds. Here are some old pics I took awhile ago. The price is $1175. Any questions please email me at jrbellas95z28@yahoo.com as my inbox fills up quick.
Turbo
Blowoff valve
piping/silicone couplers/clamps for the charge piping
intercooler if you want one
oil feed and return lines
aftermarket radiator and fans.
A/C delete pulley (for when you remove your A/C compressor)
I have links for where to buy each of these components.
I can give you more details/options if you want to email me: jrbellas95z28@yahoo.com
Blowoff valve
No need to cut radiator support with a custom radiator from http://www.ohioforcedinductions.com/
Their radiator fits under the stock radiator support and stands vertical. You can push it forward as far as possible and get a set of slimmer electric fans and should have plenty of room.
FMFRacing88
05-25-2015 08:08 PM
LT1runner
33
07-24-2002 01:19 PM
