Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 F-Body Technical Discussion > 1967-2002 Specific Technical Discussion > N2O Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 06-13-2004, 02:36 AM   #1
will NOS blow up a stock LT1?
how bad is NOS really for the motor?
will it make the motor not last as long?
how much ware and tare does it put on a motor ?
I have a bone stock 94 Z28 LT1 M6 and am doing the intake and full exhaust, looking for a little more boost when needed, just want to know how bad NOs really is on a motor.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
ZPower_123 is offline   Reply With Quote
Old 06-13-2004, 02:46 AM   #2
It won't hurt your engine as long as you don't try to run a huge shot of nitrous and make sure that you have the other safety parts.
I have been runing a 150 wet shot for years now with no problems.
Good luck
Joe
P.S. NOS is a brand of nitrous systems.
__________________
96 lt1 firebird A4
k&n cold air... descreened maf... 52mm TB... TB bypass... 160 thermostat... hypertech programmer... nitto Drag radials... NX 150 shot wet system... 3.73's... ported and polished heads... CC305... FLP longtube headers...
2nd tranny gone
up next built 4L60E... or LSx swap...
96birdlt1 is offline   Reply With Quote
Old 06-13-2004, 05:45 AM   #3
my stock LT1 with bolt on's ran 12.36@109 without nitrous,and 11.02@124 with nitrous (175 shot).
Car had no problems,ran a 150 shot for 2 years before i jumped to the 175.
Pulled the engine apart and there was NO damage inside.
NOW,YES nitrous can blow the engine up if you get greedy/careless. WHEN used properly and with the CORRECT SAFETY equipment,it can provide years of fun and trouble free running.
__________________
Dirk 2004 GTO A4 Yellow
97 TA SOLD
DYNO'S are for Tuning,not Racing
The RacinLT1
RacinLT1 pic's
RacinLT1 is offline   Reply With Quote
Old 06-13-2004, 08:59 AM   #4
Nope, just don't get greedy with it and push more then your ringlands can take or your fuel pump can supply.
__________________
94 Z28 M6 [R.I.P.] ( stupid stupid snowplow)
97 Corvette. MN6. All the goodies.
00 ZR600EFI Arctic Cat
www.bmnracetech.com
BILLJ is offline   Reply With Quote
Old 06-14-2004, 04:26 PM   #5
Garage
Send a message via ICQ to 85LT1Z28MEX Send a message via MSN to 85LT1Z28MEX
Quote:
Hey 96bird, what ETīs do you run with and without nitrous?
__________________
1:- Camaro z28 1985 LT1
2:- Firebird Formula 1995 LT1 M6
3.- Corvette 1994 LT1
4.- Camaro z28 1996 LT1
85LT1Z28MEX is offline   Reply With Quote
Old 06-14-2004, 09:33 PM   #6
I haven't gone to the track, yet. But with the G-tech pro, I was running high 13's N/A and around 13.0 to 12.8 on the nitrous.
That was before I had gears, SFC, LCA, torque arm, stock manifolds, and on street tires.
All that is a thing of the past now, I just started a heads and cam swap today. I will be running the CC305, ported and coated heads, and FLP long tube headers.
Joe
__________________
96 lt1 firebird A4
2nd tranny gone
Old 06-14-2004, 10:53 PM   #7
97SS0594's Avatar
Garage
Send a message via AIM to 97SS0594 Send a message via Yahoo to 97SS0594
mine took a dump, but my vacume line came off the fpr and it ran real lean!! but i put a hurtin on a Z06 in the process
__________________
97 SS vert #594- Gone
95 Z28 slowly comming togeather!!
97 SS vert #455- 383, F1A, AI cam
baycityrides.com
97SS0594 is offline   Reply With Quote
Old 06-15-2004, 12:34 AM   #8
What kind of safety equipment are you guys using? I have a clutch switch and a fuel pressure switch.
red_rocket_z is offline   Reply With Quote
Old 06-15-2004, 11:29 AM   #9
Send a message via Yahoo to MEAN_SBC
Quote:
I've heard of ZEX kit's doing that quite often... I won't even touch one now because I know of 2 people in my home town where that vacuum line has come off, and both of them melted a piston....
Straight up, Nitrous doesn't hurt a motor..... It's the horsepower, and extra torque that it causes the motor to produce that hurts the motor.....(but this isn't a bad thing, because horsepower is good..) An engine making 800hp with a blower, and an engine making 800hp with nitrous will see the same wear and tear factor..
The only time that engine failure is a direct result of nitrous is when not enough fuel is introduced into the mix..... But this is true of supercharged cars, turbo cars, and even NA cars.... If your mix is lean on any of the above setups, detonation will occur, and pistons and rings will suffer.
__________________
Brant
76 Camaro
10.27 @ 133.41
AmarilloRacers.Com
Rocket World Racing for Nitrous Express
MEAN_SBC is offline   Reply With Quote
Old 06-17-2004, 09:11 PM   #10
Premium Member
xxsaint69x's Avatar
Send a message via AIM to xxsaint69x
well put
As long as you have enough fuel to go with the n2o noting bad will happen WEll it might if your enigne cant handle a buttload of hp
__________________
700+rwhp 15+psi 95' Z28 M6
ATI D1 * AFR 227s * Big Bump Stick
Moser 12-bolt (3.73) * McLeod Street Twin
Baer Track Kit
* Fikse FM/5 * GMMG
xxsaint69x is offline   Reply With Quote
Old 06-23-2004, 10:17 PM   #11
Bersaglieri's Avatar
So which can feed that fuel better Wet or Dry kits? So as not to harm the inner workings of my LT1.
-Dustin-
__________________
1994 Z28 - 6.27L - 4L80 - 9"
1995 Z28 - 5.7L - T56
1995 Vette - 5.7L - ZF6 - Dana44
LTXtech.com
Bersaglieri is offline   Reply With Quote
Old 06-24-2004, 10:14 AM   #12
I'm a bigger fan of wet kits, just because you have an extra solenoid supplying the fuel, and you don't have to worry about the limitations of the stock injectors... I'm pretty sure that you can safely run 100-125 shot by tapping in to the fuel test port (schrader valve) on an Lt1, or LS1... That makes it super easy to install.. I've seen many Ls1, and Lt1 guys run that much power this way, and I've only seen one mess up... (burnt a valve with a 200 shot on a stock LS6 in a Z06), but like I said 100-125 shot should be fine.
__________________
Brant
76 Camaro
10.27 @ 133.41
AmarilloRacers.Com
Old 06-24-2004, 08:10 PM   #13
Hey guys,
So say my Z28 is all stock but it has 125,xxx that are mostly all highway and it was lady driven, i had the intake manifold off and it was like perfect. but i am gunna do full exhaust, lpe cai, and couple other things, but i wanna do like a 100shot, would my motor handle it, if not what may happen?
thx rob
Bigrob339 is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
