Suggestions for initial hit?
Old 08-09-2008, 11:44 PM
cad78's Avatar
I have a 96 6speed Z with a nearly stock engine, just recently had new rings, bearings, oil pump, timing chain installed. It has some larger Crane valve springs and Gold 1.6RRs.
Other than that, it's really a stock POS that I got for $500
I am installing an 8.5 rear w/3.73 and some 315/60/15 MT Drag radials. I have a 35# co2 bottle that has been converted to no2. I have a NOS wet plate, and a micro throttle switch. I have a Innovate WBo2.
I want to run e85 and maybe a 150 shot, where do I start?
I've read the last 10 pages of n20 tech, and know to get the TR6 plugs and maybe the Mallory 685box? What else do I need to do? What pills will work with e85? What fuel pressure? I need an AFPR, which brand? I have plenty of LS7 fuel pumps, so I was thinking 2 intank, maybe turn on 2nd with the no2? I really don't want to buy headers just yet, probably will just gut the cats. This is just a stupid project, so I'm not looking for perfection, just something for fun a few times.
Thanks, Christian
cad78 is offline
Old 08-10-2008, 10:44 AM
Seems like an unusual approach:
-30" tires are going to be a tight fit on a 4th Gen. They will make your 3.73's feel like 3.23's.
-why lug around the bulk of a 35# pressure tank? With the weight of the tank and the nitrous you are carrying about 40# of excess weight.
-it there's one thing nitrous needs, its "big" exhaust".
-why do you feel you need an AFPR? You select the fuel jets based on the operating pressure of the system. If all you are doing is going with a double pump system through the stock fuel lines, you will want to hold the fuel pressure at the stock 43.5psi (measured with no vacuum compensation line).
Injuneer is offline
Old 08-10-2008, 11:55 AM
cad78's Avatar
The wheels/tires were kinda laying around. They actually fit with the 8.5 rear very well. The NO2 tank was also just laying around, and I figure it's weight is ok over the right rear, no? I want to run e85, I thought that I needed to compensate for the stoich with a little more FP, am I wrong here? I agree with the exhaust and all your suggestions, just trying to have a little "cheap" fun.
My dad just wants a 57 chevy like http://www.easyrods.com/ or http://www.chevyrods.com/default.asp
We were just looking to have a little fun with stuff we had. There's a brand new e85 pump down the road, we figured we wouldn't have to retard timing with it and a 150 shot?
cad78 is offline
Old 08-11-2008, 11:51 AM
slomarao's Avatar
just get a cutout for the n20. leave the cats in my opinion. Pick up a window switch, Fpss, blow down tube.
Dont think your going to need stand alone fuel for a 150 hit. Especailly since you ll be running e85 already.
No need for a adj fuel pressure regulator.
slomarao is offline
DirtyDaveW
12-01-2016 05:37 PM
4586
03-18-2015 06:31 PM
NewsBot
03-13-2015 07:15 AM
mark0006
02-03-2015 05:12 PM
Red97LT1
9
12-17-2014 06:13 PM
Quick Reply: Suggestions for initial hit?
