Stock 4 bolt bottom end. BRAND new thinking n20 help..
ok just as the title says ill have all the mods in sig plus 52mm tb, 36lb injectors, ported intake. ill be installing a brand new gm 4 bolt main shortblock and i was wondering with the cam and all the mods if a 100 shot of nos would be safe. im thinking about studding and putting better caps on the mains just to be safe... ill get an ignition box to do the timing....let me know your thoughts all you n2o gurus out there...thanks
I'm pulling 9 degrees (685 box) and my tune from Ion does not have any timing added to it. Don't forget to install a colder plug like the BR7EF gapped at .032. I also throw a few gallons of unleaded 104 octane in the tank when spraying.
What kit are you using?
