stand alone fuel system
I have someone that will make me a 1 gallon fuel cell for my car for the nitrous kit n wanted to know what style fuel pump I need, holley blue or an efi pump? Also about what psi do most people run their system? Just doin it to put race gas in it and try to avoid leaning out the in-tank pump
Re: stand alone fuel system
Depends on what jets you have for your kit. If you have it setup for low pressure, run a Holley pump. High pressure needs something similar to normal EFI pressure, 40-45psi.
Are you running a small shot, big shot, how many nozzles, etc. You can always use the windshield washer reservoir for the fuel cell. Seen that done before.
-Dustin-
-Dustin-
10-31-2016 11:09 AM
07-04-2005 05:00 PM
