Spraying Nitrous
Old 08-03-2009, 04:54 AM
93BlackTA's Avatar
Spraying Nitrous
I have a 6 spd car and i have my nitrous setup on a WOT switch...Is there anyway to setup the nitrous so that when its turned on it doesnt spray in 1st or 2nd gear but when i hit 3rd gear it sprays....I also have it hooked up to a mallory 685 box and set to spray at 3000-6000rpm
93BlackTA is offline
Old 09-22-2009, 04:24 PM
Mr_Bond's Avatar
Your going to need a "any gear" lock out window switch like this one
or this one
You can still use the mallory to retard the timing, just use one of these as the window switch.
Mr_Bond is offline
Old 09-22-2009, 10:23 PM
97 RedSS's Avatar
I have the nitrous outlet switch and it works great..
97 RedSS is offline
Jeff1904
06-05-2016 05:00 PM
RUENUF
03-13-2016 03:37 PM
Quickss96
01-29-2016 05:56 PM
95blkss
09-22-2015 03:18 PM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: Spraying Nitrous
