Engine damage if you run out of n20 while spaying?
Old 03-05-2003, 01:15 PM
stik6shift00's Avatar
Say you run out of nitrous while your spraying....will that mess your engine up?
stik6shift00 is offline
Old 03-05-2003, 01:56 PM
Geoff Chadwick's Avatar
You'd run really rich, but if you kept it up you might hydrolock if there's a LOT in there and the spark cant burn it all... but wouldnt you notice the nitrous pressure dropping first?
Geoff Chadwick is offline
Old 03-05-2003, 02:36 PM
COMNBYU's Avatar
no. if you ran out of n2o while spraying you would feel the car nose over or studder in which case you would let off. it wont hurt the motor, but if you keep in it, the motor will simply cut off. all you're doing if you keep adding fuel w/o n2o is flooding the motor. not too big of a deal.
now, if you add n2o w/o fuel, then you have a problem
its called detonation (A.K.A.- BOOM, POP, PING, BAANNNG!!)
jon
COMNBYU is offline
Old 03-05-2003, 05:19 PM
stik6shift98's Avatar
dont spray when u have no pressure........
stik6shift98 is offline
Old 03-05-2003, 07:19 PM
lmao stik00 i see u sid spating...i think u meant spraying...
i ran my nitrous with low pressure about 600 and i was running really rich...
Old 03-06-2003, 12:07 PM
stik6shift93's Avatar
It'll foul your plugs up, and it isn't great for the cats either.
stik6shift93 is offline
Old 03-06-2003, 12:16 PM
chesee48's Avatar
What happens if your using no cats?
chesee48 is offline
Old 03-06-2003, 12:41 PM
No cats=no worries. Cats like to be run around 14.7 af, not like 6 to 1 or something similar that would be seen spraying without the nitrous. The fat of an af mixture will ruin your cats if it happens enough.
Old 03-06-2003, 06:21 PM
nothing...because your not hurting the cats since their not there
Old 03-06-2003, 06:52 PM
thanks alot..ill just cheak the presure before
Old 03-07-2003, 02:02 AM
Twice The Fun's Avatar
this is just my thought, but if u feel it run out of juice, couldnt u just disarm it (aka flip the switch off), and finish the run all motor....with no damage done?
Twice The Fun is offline
Old 03-07-2003, 09:43 PM
treyZ28's Avatar
Location: looking for a flow bench so Brook and I can race
my friend and i wondered the same thing
flipped the switch with the bottle closed-
car just stuttered
treyZ28 is offline
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
97z28k&N
01-09-2015 04:58 AM
Quick Reply: Engine damage if you run out of n20 while spaying?
