question on nitrous plate
Old 07-29-2011, 10:33 PM
shawngamblez28's Avatar
never played with nitrous an had a few questions.1 will a tune port nitrous plate work on an lt-1 with a twin 58mm throttle body an a ported intake manifold.2 would i b safe running a 125 shot.3 do i need a purge on something that small.4 do i just hook up to my fuel rail shreder valve .thanks for ur input
shawngamblez28 is offline
Old 08-16-2011, 08:44 AM
95zsean's Avatar
Re: question on nitrous plate
I dont know about the plate, 125 would be fine with pulling time and the right plugs. Yes you need a purge valve to get the nitrous to the solenoid so it's there when you hit it, not air and fuel. You can draw fuel from the shreder valve, just make sure you run a fuel pressure safety switch, so if you drop FP it will shut the nitrous off.
There's ALOT to nitrous, who ever said "HP on the cheep" never had nitrous.LOL there are a lot of good dealers that can help you out, have a look around the net. The one I used was Nitrous Outlet.
95zsean is offline
camaroguy50613
05-27-2016 09:00 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
alphaauto
01-23-2015 07:42 AM
bandit383lt4
12-21-2014 09:12 PM
Quick Reply: question on nitrous plate
