nitrous pressure gauge sensor wiring question
So I'm installing a glowshift pressure gauge on my dash, and the sensor fitting is similar to my pressure bottle warmer. The pressure sensor for my bottle warmer is under my hood, can I tap the wires into that for my pressure gauge so I don't have to tap in another line connector for my gauge sensor?
Re: nitrous pressure gauge sensor wiring question
Most pressure sensors are variable resistance based devices. If you connect them to two circuits in parallel, it will screw up the readings.
Brandon Wittmer
12-03-2014 09:28 PM
07-04-2005 05:00 PM
